Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] Beginner Coordinate Question
Old   March 24, 2013, 08:46
Default Beginner Coordinate Question
AJ Hunter
ajhunte is on a distinguished road
Is there a tool that allows you to determine the exact coordinates of a specific point? I need to find the (x,y,z) for the center of a circular face in my geometry. I couldn't find anything on the ANSYS tutorials that shows you how to measure this for an existing geometry.
Any help would be greatly appreciated.
ajhunte is offline   Reply With Quote
Old   March 25, 2013, 05:37
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Do you need to know it, or is it sufficient to place an origin there? If you select a circular surface and create a new plane, you will have the plane origin in the center.
In ansys meshing you can create a coordinate system in the same manner, and also find out what the global coordinates are from the coordinate system details.
jrunsten is offline   Reply With Quote
Old   March 25, 2013, 09:29
AJ Hunter
I have placed an origin there and am importing interpolation data into x,y,z coordinates. I want to make sure that my data is importing correctly into my user coordinate frame. In order to do this I want to run my simulation with the same data, but shifted to match what the Ansys coordinate frame is. If I get the same results both times, then I can just use the user frame from here on out. The problem is, no one seems to know how to find the coordinates of a given point in the DesignModeler for Ansys.
Old   March 25, 2013, 09:39
Josef Runsten
Just open the model in Ansys meshing and create a coordinate system on the surface. Then you'll get your coordinates. Then go back to DM and continue modeling.
Thread Tools
Trackbacks are On
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
Beginner question :(. Turning on and off zones? Cjlaumans FLUENT 6 September 2, 2009 15:44
Spherical coordinate system ehsan_vaghefi OpenFOAM Native Meshers: blockMesh 0 September 3, 2008 22:31
Beginner question OddEven Decoupling in SIMPLE Solver brooksmoses OpenFOAM Running, Solving & CFD 2 November 9, 2005 20:38
Question from a beginner Arun K Main CFD Forum 4 August 13, 2004 07:17
