[Workbench] Workbench (Engineering dara) problem
Like Tree2Likes
  • 1 Post By dkx209
  • 1 Post By dkx209
Old   March 27, 2013, 06:57
Default Workbench (Engineering dara) problem
Moha
ahvz is on a distinguished road
I defined enthalpy-temperaure values for a material in "engineering data" but there is sign "?" next to the name of the material. if I put a tik for "suppression" it will ignore the enthalpy then the problem will be solve (does it means, ignoring enthalpy for materials properties ?).
regards,
ahvz is offline   Reply With Quote
Old   March 30, 2013, 19:10
Engineer
dkx209 is on a distinguished road
Question mark appears when you haven't defined a single property. I don't know how you are defining the material but try this.
Either try to duplicate one of the existing material and change its property, or to add a new material all by yourself, Start Engineering Data and click on Engineering Data Icon, (similar to Winrar, you will find it in top panel at right).
Now you will see different materials groups pre-defined in workbench. Scroll down to the end and click on Add New and name it, save somewhere.
Now DO CHECK THE BOX in front it to make it editable. Now you will be able to add your material. Once done, add which ever property you want to specify and then in the Material Class table, uncheck the box and click on save.
ahvz likes this.
dkx209 is offline   Reply With Quote
Old   March 31, 2013, 05:59
Moha
thank you very much for reply, done!
Old   March 31, 2013, 07:33
Engineer
Glad to hear that.
ahvz likes this.
Old   February 17, 2017, 02:41
Default engineering data
ruthran
ruthran is on a distinguished road
i am using ansys 16.2 .i edit endineering data file .i click genaral materials its not display any metals why?
please help me quickly
ruthran is offline   Reply With Quote
ANSYS Workbench mesh crashes (ANSYSWBU.exe problem) kondan ANSYS 76 February 22, 2024 02:27
[ANSYS Meshing] Problem in updating the mesh in Workbench victorz ANSYS Meshing & Geometry 23 October 31, 2017 02:52
Engineering data (workbench application) to FLUENT ahvz FLUENT 0 March 29, 2013 10:04
Problem of contact on Ansys Workbench 11 Benjaminleb ANSYS 4 May 28, 2010 02:07
Workbench engineering data model zegtuhetmaar ANSYS 0 February 9, 2010 06:55
