-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [Other] Return with error code 1 (http://www.cfd-online.com/Forums/ansys-meshing/115410-return-error-code-1-a.html)
darazsbence March 30, 2013 08:10
Hi Everyone,
I have a problem concerning error code 1 and don't know what to do. I would like to continue a SST run with and SSG so when I define my new run I select the . def file of the SSG setup and then check the box that says initial values and there I select the SST run .res file. I tried double precision too, but it would't work.
Seperatly, the SSG and the SST setup ran without any problem, I used the same mesh and boundary conditions, and only changed the turbulence model.
Thanks everyone in advance.
Hybrid March 30, 2013 08:47
Post your question to the relevant forum, with details which solver you are using etc.
