[ANSYS Meshing] Inflation layer _ Boundary Problem
Old   March 30, 2013, 19:46
Default Inflation layer _ Boundary Problem
Elina Mathew
elina is on a distinguished road
Hi
When I am giving some mesh where there is a solid part (Sphere) and a an enclosure which is considered to be fluid (Rectangular Box) and while meshing I have to mesh the surface between the solid and fluid as fine meshing or have to give some inflation layer , but when I go for that option its asking for boundary which I am not able to give any boundary...I am able to select the named selection of Inlet but then its asking for boundary ..which I cant give in any way..and I just want at the inlet region little fine meshing...since the flow starts from there....and also on the surface of the solid where the fluid flows since its a heat transfer problem so have to see the heat transfer...
Kindly have a look at my geometry and tell me ....I hope you can understand better...I have to mesh the sphere in such a way that I get very less number of elements and the fluid zone as the hexa mesh and have to see the outlet temperature for different number of elements in fluid zone and solid zone....
Kindly help me ....in these two problems....
Thanks in advance
elina is offline   Reply With Quote
Old   March 31, 2013, 07:48
Engineer
dkx209 is on a distinguished road
Elina there must be a folder with your file named as my_assignment_files. Please also zip that as well.
dkx209 is offline   Reply With Quote
Old   March 31, 2013, 08:03
Elina Mathew
Ah sorry..here it is.....kindly have a look and pls tell me...
Old   March 31, 2013, 08:30
Engineer
Elina please check the attached image, is this kind of mesh you are looking for? Because this is what I got from your question.
Old   March 31, 2013, 08:47
Elina Mathew
Hallo Sir
I would say no Becoz from that I can see the elements for both sphere region and fluid region all together comes in the range of 10^5 if I am correct..we actually doing a heat transfer simulation and the spheres are granite and just on the surface we need a bit fine meshing and towards the depth of the sphere we need very less number of elements..from yours I can see its fine mesh over the volume and we need a structured mesh so the sphere can me meshed like say layers (like Onion) or like concentric spheres just the meshing the geometry is just one sphere....See the image attached...and there the layers are having some thickness....like that...Hexa meshing
I am not able to do this type of meshing in the ansys workbench....and also how to do that fillet between the two contact of spheres....???
GAMBIT meshing problem for boundary layer Falah FLUENT 2 November 30, 2020 14:16
High aspect ratio mesh problem for flat plate boundary layer sam1364 OpenFOAM 3 May 14, 2020 11:11
problem with boundary layer Bharath Main CFD Forum 1 July 11, 2008 09:06
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
