July 31, 2012, 18:00 |
Mesh refinement
Meimei Wang
Rep Power: 15 |
Hi
After the Pre-Mesh quality was adjusted well ( the quality was above 0.5 ), I used the button 'Pre-mesh Params -> Refinement' to refine the pre-mesh. Then I check the quality of the pre-mesh. The quality becomes bad again. If I convert them to mesh firstly, then use the mesh refinement button, this problem may still occur. May I ask how to solve this problem?
Best regards, Meimei |
July 16, 2014, 08:22 |
Rep Power: 11 |
Hello Anna,
do you have solved this problem? In my case, icem puts some thin elements between the zones after the refinement. |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
Mesh refinement and the errors. | Korsh Mik | CFX | 0 | January 11, 2006 07:07 |
