-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Problems with boundary condition (http://www.cfd-online.com/Forums/ansys-meshing/115579-problems-boundary-condition.html)
leo_NM April 2, 2013 14:43
2 Attachment(s)
Good afternoon.
I'm dealing with ICEM steep learning curve, I solved the problem (thanks guys from CFDonline) with the points of the airfoil. Now I'm having problens with Fluent recognizing my boundary conditions.
The method I used was:
1- Draw the farfield and defined the curves with names ENTRADA (inlet); SAIDA(outlet), PAREDES(upper and down wall) and AEROFOLIO (airfoil).
2- I saved *.msh using ANSYS Fluent and NASTRAN as solver. I Know that the ideal case would be ANSYS Fluent and ANSYS as solver, but this is the third time I try to define the boundary, in the other tries I selected ANSYS Fluent and ANSYS as solver.
3- Defined the boundary conditions ( see the pictures).
How can I configure ICEM + Fluent to recognize my Inlet B.C.
I attached some images.
thanks !
Far April 2, 2013 23:42
you need separate curve and edge for ICEM to recognise the boundary condition.
http://www.cfd-online.com/Forums/ans...em-fluent.html
