April 23, 2016, 13:55 |
Velocity flow inside MRF zones
#1 | |
shuk
Rep Power: 10 |
Hello everybody,
i have meshed(tetra) a cylinder with concentric cylinder as rotating zones by : > mesh concentric part [in ICEM] >mesh outer part [in ICEM] >import meshes to fluent (by append the case) [in fluent] > mesh interfaces of the shadow wall [in fluent] >assigned the rotating part as frame motion with rpm of 600 [in fluent] >assigned velocity magnitude of velocity inlet [fluent] > assigned model+solution method [fluent] > RUN [fluent] >1st pic meshes & 2nd pic velocity pathlines Should the vector at velocity inlet start swirling as soon it flows into static domain before it reach the rotating part as in the picture??? by reffering to my previous posthttp://www.cfd-online.com/Forums/flu...-boundary.html and Quote:
MRF solvers give diffenrent results when MRF zone's diameter is different | sharonyue | OpenFOAM Running, Solving & CFD | 10 | May 31, 2022 04:46 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
rotating wall inside of an MRF zone - fixedValue or movingWallvelocity? | evrikon | OpenFOAM Running, Solving & CFD | 3 | April 30, 2015 03:51 |
Modelling the Heat flow inside the curing oven | Marios Vlad | CFX | 1 | February 6, 2008 07:11 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
