[ANSYS Meshing] Not able to mesh flow region only surface of body
Old   April 3, 2013, 15:43
Default Not able to mesh flow region only surface of body
FredRaw is on a distinguished road
Hi guys!
I am quite a rookie at CFD and have a fairly complex problem to solve. Trying to simulate the fluid flow in a static N-mixer.. I have imported the geometry from solidworks into Ansys workbench, specified the mixing element as solid and the enclosing pipe as "fluid", or body surround the mixing element. When I try to mesh the flow path, the mesh is only on the surface of the bodies and not covering the flow path. What have I done wrong, or what am I missing?
Thanks for any suggestions and advice
Regards
Fredrik
FredRaw is offline   Reply With Quote
Old   April 4, 2013, 01:27
Far
Sijal
Either display cut plane or import mesh to Fluent in-order to see whether the volume is meshed or not.
Old   April 19, 2013, 05:06
Thanks for your answer! I´ve used a option called fill, to make a new body for the flow area and specified it as a fluid. Now it seems that I am able to mesh the fluid volume.
Best Regards
Fredrik
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
PEM fuel cell simulation pchoopanya Mesh Generation & Pre-Processing 1 February 29, 2016 23:56
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
