-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Wind turbine blades meshing (http://www.cfd-online.com/Forums/ansys-meshing/115752-wind-turbine-blades-meshing.html)
kiddmax April 5, 2013 18:02
1 Attachment(s)
Hello all.
I want to generate the mesh for horizontal wind turbine blades. the turbine has two blades. In order to reduce the computational time, I want to generate the half circular computational domain, see the pic. and use periodic boundary conditions for the two different color surfaces.
And My questions now is: If I want to be able to define the two surface boundary conditions,let's say perid_1 and perid_2. That means I have to associate edges or vertices or faces to the "real" surfaces. Now I can not generation right O grid around airfoil due to there have two block at the lowest surface, I think, and the result seems uncorrected resulting in making O grid fail.Does it come from the two blocks main in the surface. Does someone have a better idea to solve it?
Pospelov April 17, 2013 14:09
It's hard to say. Is it possible to post the tin file, because if you have a half wind turbine you should have a half hub, but I cannot see it in your picture.
You have got something, but I cannot exectly see what is it.:)
