[ICEM] How to run ICEM over parallel processor? |
April 4, 2013, 11:07 |
Astio Lamar
Rep Power: 13 |
Hello!
I want to run ICEM over parallel processing. I follow the path "Settings => General => number of processors" to assign number of the processors which I want to used by ICEM. But it doesn't work and still ICEM used just one processor. Any idea about this issue? |
April 4, 2013, 11:50 |
AB
Rep Power: 21 |
It's not a bug, ICEM can use more than 1 proc only for some operations, not all the time.
April 4, 2013, 12:44 |
Astio Lamar
Rep Power: 13 |
Hi!
What do you mean by some operations? Why not for the all? And what is those operations? Thx. |
April 4, 2013, 13:53 |
david
Rep Power: 13 |
what is it exactly that you wanna do with the multiple processors?
April 4, 2013, 14:23 |
Astio Lamar
Rep Power: 13 |
Since I have huge number of node in a geometry, after each modification, it takes a very long time to see check the quality and/or mesh preview. ICEM just use one processor out of 12 (around 7%). So if it run over the whole, then I got much more speed.
April 5, 2013, 15:51 |
david
Rep Power: 13 |
i am checking with the ANSYS people in Calgary and hopefully they will give me a reply
April 8, 2013, 03:17 |
Astio Lamar
Rep Power: 13 |
Hi!
Since I ask for the answer and I got reply, I want to share it with the others. Only the volume meshing using the Octree approach can take advantage of the parallel option in ICEM! |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
Case running in serial, but Parallel run gives error | atmcfd | OpenFOAM Running, Solving & CFD | 18 | March 26, 2016 12:40 |
error in parallel run | immortality | OpenFOAM Running, Solving & CFD | 7 | January 1, 2013 13:35 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
