-   ANSYS Meshing & Geometry (
-   -   [ICEM] Split surface (
RPFigueiredo April 10, 2013 11:00
Split surface
2 Attachment(s)
Hello again!
Here's the issue - it's quite simple but I'm don't know how or even if it is possible to do it. I want to split a surface at a determined location. I can achieve what I want by creating a curve between two points and hen using it to split the surface (as seen on the images below).
Attachment 20640
Attachment 20641
However,k the actual location of where I want to split the surface is not at those points (intersection between the horizontal curve and the vertical line). I would like to split at a certain normal (y-axis) distance from the back of the model.
One way of doing it would be by creating a curve from two x,y,z points. However, it would be easier if I could somehow set a normal distance from the exit surface.
Does anyone have any ideas to help me? Or should I just go to Solidworks and get the x,y,z coordinates?
Thank you in advance!
stuart23 April 15, 2013 03:18
I would offset the outlet surface by the particular value then use the offset surface to intersect with your hub. Once you have created the split, you can then delete the offset surface. I think this would be easier than going back to CAD
RPFigueiredo April 15, 2013 05:17
