April 5, 2013, 18:02 |
Wind turbine blades meshing
Ye Zhang
Rep Power: 16 |
Hello all.
I want to generate the mesh for horizontal wind turbine blades. the turbine has two blades. In order to reduce the computational time, I want to generate the half circular computational domain, see the pic. and use periodic boundary conditions for the two different color surfaces. And My questions now is: If I want to be able to define the two surface boundary conditions,let's say perid_1 and perid_2. That means I have to associate edges or vertices or faces to the "real" surfaces. Now I can not generation right O grid around airfoil due to there have two block at the lowest surface, I think, and the result seems uncorrected resulting in making O grid fail.Does it come from the two blocks main in the surface. Does someone have a better idea to solve it? |
April 17, 2013, 14:09 |
Alexander
Rep Power: 16 |
It's hard to say. Is it possible to post the tin file, because if you have a half wind turbine you should have a half hub, but I cannot see it in your picture.
You have got something, but I cannot exectly see what is it. |
[ICEM] Problems with meshing of wind turbine | Dosis | ANSYS Meshing & Geometry | 14 | November 13, 2012 05:41 |
FSI - Wind Turbine | AUN | CFX | 13 | August 29, 2012 16:44 |
Analyses and Design of Wind Turbine Blades, please help!!! | heavymag | Main CFD Forum | 7 | April 13, 2012 16:51 |
[GAMBIT] Meshing a wind turbine for wing tip vortexes | Grog106 | ANSYS Meshing & Geometry | 1 | March 29, 2012 06:07 |
How to Mesh For Wind Turbine Blades for CFD Simulation in Hypermesh? | haristrawberry | Main CFD Forum | 3 | November 12, 2010 06:27 |
