Home > Forums > ANSYS Meshing & Geometry
[ICEM] Merge Mesh
Old   April 15, 2013, 03:16
Default Merge Mesh
Javi
FJSJ is on a distinguished road
I would like to know if "merge mesh" works with hex/hex mesh or at least one of this must be tetra/tri mesh?
FJSJ is offline   Reply With Quote
Old   April 15, 2013, 03:53
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
one of them must be tri. Hexa- hexa should work well if you have one to one interface I guess.
Far is offline   Reply With Quote
Old   April 15, 2013, 04:01
AB
BrolY will become famous soon enough
If you want to merge Hex mesh with another Hex mesh, you need a conformal interface between the 2 meshes (i.e. the exact same interface with the exact same node repartition), and then use the "merge nodes" option rather than "merge meshes".
BrolY is offline   Reply With Quote
Old   April 15, 2013, 06:55
Javi
Ive tried to do something similar. I have my entire domain split into 3 parts. First, Ive done the first blocking and first mesh. Ive saved blocking and mesh. Second, Ive done the second blocking (merging blocks) and the second mesh and I get this. So..I think something wrong because the second mesh is (only a part) like the color of first one. Do you know why is it?
Old   April 15, 2013, 11:27
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
FJSJ, sorry I'm not sure i understood what you said. please can you re-formulate.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   April 15, 2013, 12:51
Javi
Sure. I have the entire domain divided into 3 parts. First, I do the blocking and mesh in first part. I save the blocking and mesh then close the block and mesh. Then I do the same with the second part of the domain.
But as you can see, in the first part in "Interface 1", no problem. But, on the second mesh, "Interface 1" is a sector only. The rest is associated to another part, instead of associating the "Interface 1" (as in the mesh 1)... Im not sure if I explain well.
Ive tried to follow similar approach like "Merged Tetra-Hexa Mesh in a Hybrid Tube" tutorial. Maybe the problem is the curves association...
Old   April 15, 2013, 13:30
diamondx's Avatar
Ghazlani M. Ali
i have more questions: What do you mean by sector only ?
Why did you separate the block in three part ?
Did you try merge blocks ?
Can you share your project using the public dropbox file ?
Regards,
Ali
Old   April 15, 2013, 14:02
Javi
I separated the blocks because is easier to do the block on transition part of my blade. For this reason Ive not tryed merge blocks. Ive tryed to do something similar to BrolY told me. Yes, Im going to share the project but right now dropbox isnt work well.
Old   April 15, 2013, 14:06
Javi
at first, you can view the premesh in part 1. Then, you can open the block "bloque 2" and merge it.
Then view the premesh in this second block.
https://www.dropbox.com/s/yofo3a4vwe...MergeMesh1.rar
Old   April 15, 2013, 14:17
diamondx's Avatar
Ghazlani M. Ali
Are you aware that you have overlapped surfaces... for one block it may be part of interface_1 and for the other one it may be part of FLOW_DOMAIN_TRANSITION
you can fix that, by doing a doing a build topology in the repair geometry...
Regards,
Ali
Old   April 15, 2013, 14:59
diamondx's Avatar
Ghazlani M. Ali
take a look at my blocking without splits:
Project file is here:
https://dl.dropboxusercontent.com/u/...MergeMesh1.zip
Regards,
Ali
Old   April 15, 2013, 15:50
Javi
Thank Diamondx, youre right. I have overlapped surface. Ive delete them and now I think its ok.
Understood. It is better not split. I guess you get with 2 O-grid through the ends and then with a horizontally split? It is?
Old   April 15, 2013, 22:27
diamondx's Avatar
Ghazlani M. Ali
ok; i could make another blocking similar to the one in youtube (by simon). minimum quality is 0.4, it can be improved more
link for the project is here:
https://dl.dropboxusercontent.com/u/...MergeMesh1.rar
Regards,
Ali
Old   April 16, 2013, 02:31
Far
Sijal
How you will manage sharp trailing edge and circular pipe beneath blade
Old   April 16, 2013, 02:51
Javi
That is the problem area. Because for a cylindric section O-grid is the best. However, for the other part of the blade not .. so ... how to make a block support the other... I mean how to pass from one topology to other one
Old   April 16, 2013, 03:04
Far
Sijal
Solution would be to give a finite thickness to trailing edge, if it does not cause in- accuracy...
Old   April 16, 2013, 03:12
Javi
But I need a sharp trailing edge so... I think here is the problem
But... I think Diamondx managed it!
Old   April 16, 2013, 03:15
Far
Sijal
Yes. Strategy by diamondx is good.
Old   April 16, 2013, 04:17
Javi
Thank you dimaondx!
You get a good quality in all blade. But why do you create top and down part?
I supposed that is because this part is hard to adjust but im not sure...
Thanks again!
Old   April 16, 2013, 04:25
Far
Sijal
can you share bigger picture of your project. I mean blade with hub and farfield volume...
Thread Tools
Trackbacks are On
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
How to crop a mesh or merge layers Opxah OpenFOAM Meshing Format & General Technical 1 May 31, 2011 07:32
[ICEM] Merge mesh - non manifold vertices BrolY ANSYS Meshing & Geometry 4 October 30, 2010 22:07
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
