stirred tank meshing
2 Attachment(s)
Hi all
I cant mesh my geometry(stirred tank by MRF or SM), because I dont know how should start mesh process. I dont know how prepare geometry to meshing. please help me. Thanks in advance |
Is that your entire geometry? If so, you do not need MRF's
Why not need to mrf? |
If the tank is cylindrical and shares the same axis as the rotor, why not just have a SRF with counter rotating walls? There is no need for MRFs in this case.
I have not previously experienced srf. Also, I think my main problem is meshing. please help me Thank you so much |
I think that I cant use SRf because:
"Many problems involve multiple moving parts or contain stationary surfaces which are not surfaces of revolution (and therefore cannot be used with the Single Reference Frame modeling approach)" I used mrf and results were satisfactory(by another geometry for impeller). please help me about meshing this geometry |
Looking at your geometry, every other surface except the mixer is a surface of revolution. Read Fluent User Guide 9.2.2.1.1, it is exactly the same as your case.
My mesh quality very bad because I use auto mesh. Thanks in advance |
Your case is much simpler than this one. So you can easily mesh it with full Hexa
But I cant mesh that, because I dont know how should start mesh process. can you help me? |
Do you have complete geometry of your model? did you make it any CAD software or ANSYS? Can you share it?
If possible, please send to me your email. |
email is there with my name on left side ;)
Ok. got files and imported to ICEM. I hope I will come up with high quality mesh in ICEM
http://imageshack.us/a/img35/6255/stirrtank2002.jpg http://imageshack.us/a/img254/9585/stirrtank2001.jpg |
Two blades are still remaining. Other two are blocked with o-grid.
https://dl.dropboxusercontent.com/u/...tank_Jamal.zip http://imageshack.us/a/img541/183/stridtank2008.jpg http://imageshack.us/a/img687/9444/stridtank2001.jpg http://imageshack.us/a/img33/6047/striiringtank001.jpg http://imageshack.us/a/img541/6766/stridtank2002.jpg http://imageshack.us/a/img843/3479/stridtank2004.jpg http://imageshack.us/a/img444/1461/stridtank2007.jpg http://imageshack.us/a/img201/6255/stirrtank2002.jpg http://imageshack.us/a/img5/6041/stridtank2003.jpg http://imageshack.us/a/img4/7914/stridtank2006.jpg |
I waiting to that Best Regards |
