[DesignModeler] Mohammad Hashem
Old   April 14, 2013, 03:48
Default Mohammad Hashem
Mohamad Hashem
hashemmohammad is on a distinguished road
Hello Guys
I am new to this forum. I started using ansys 2 months ago and till now I don't know how to choose the interior of a body. Attached is a picture that explains my problem. I have drawn a small sphere and frozen it. Then I drew a big box around it and subtracted them from each other without preserving the sphere. Now I want in fluent to define the interior surface or the sphere as a heat source. How can I do this??
Thanks in advance
hashemmohammad is offline   Reply With Quote
Old   April 14, 2013, 10:11
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
on top, you can filter the selction to points, edges, surfaces, and bodies. you have to toggle on the surface selection. then select the surface of the select. right button click -> rename selection, give it a name first: like WALL_SPHERE. once this will be meshed, it will appear in fluent as a boundary condition
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 14, 2013, 17:14
Mohamad Hashem
Thanks Diamondx but I didn't manage to solve the problem. I tried what you have said but I couldn't locate the interior sphere surface?? What can I do?
Old   April 15, 2013, 11:10
Dr.Hayder Mohammed
Hayder Mohammed is on a distinguished road
Send a message via MSN to Hayder Mohammed Send a message via Yahoo to Hayder Mohammed Send a message via Skype™ to Hayder Mohammed
hello mr mohammed,
go to the mesh ,before you make a mesh , make a right click on any face and then select hide face ,then you can select the ball and make a named selection for it ...by this way you can select and define any part on your geometry
best regards
Hayder Mohammed
M.SC in CFD
Hayder Mohammed is offline   Reply With Quote
Old   April 15, 2013, 11:30
diamondx's Avatar
Ghazlani M. Ali
share your project if you don't mind...
Regards,
Ali
Old   April 15, 2013, 19:25
Mohamad Hashem
Thanks a lot Guys Haydar and Diamondx. I have located the sphere by doing what diamondx has initially implied and used the planes that appear down-left to choose the hidden face.
Thanks again
Thermophysicalproperties in rhoCentralFoam srinath OpenFOAM Running, Solving & CFD 12 October 2, 2012 10:04
