Home > Forums > ANSYS Meshing & Geometry
[ICEM] problem when reading mesh
Like Tree2Likes
Old   April 24, 2013, 05:38
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
so your problem is the periodicity and not the mesh? How did you setup periodicity?
Far is offline   Reply With Quote
Old   April 24, 2013, 06:17
christine
yorelchr is on a distinguished road
I can read the other parts of my geometry, this is the only one I cannot read.
For all the other parts, I have periodicity problem: all the periodic zones are considered as translational, I can change in Fluent to rotational but then the angle is equal to 0 and I don't find where I can give Fluent the real value of the angle.
I couldn't read your file (Far) since some files are missing. Or can I use mine to complete (*.uns..)?
Rodriguez: I don't have this message, when it starts to read the mesh, appear the message I've posted before. Can you explain me how you deal with periodicity in Fluent?
I am working on Linux, Fluent in parallel.
yorelchr is offline   Reply With Quote
Old   April 24, 2013, 06:21
christine
sorry, I didn't see this post before replying.
For periodicity I did :
Mesh/Global Mesh Setup, then Set-up periodicity (basis 0.0.0, axis 1.0.0 and angle 45)
Blocking/Edit block, then Periodic Vertices
Then in Output/Boundary Conditions, I give the periodic conditions to the surfaces
Old   April 24, 2013, 06:28
Far
Sijal
Instead of default method choose "vector option and select two points of axis of rotation (make these points by yourself). Also when you apply Y-block every thing goes away like edge mesh parameters, association and even periodicity. So you have to again associate, again define periodic vertices and again specify edge mesh parameters (This is bug I think in R14.5) and then you are done.
PS. 1. Files I have uploaded are saved in R14.5. Are you able to open .tin and .blk if yes then you can get generate mesh yourself.
2. I am attaching a sample project done for you where periodicity is applied.
Old   April 24, 2013, 06:31
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
In Icem: You just need to give some name to each surface you want to become periodic, such as "front" and "back" or whatever. Export your mesh.
In Fluent: Go to the "Cell Zone Conditions" and click on each of the surfaces. Note the "ID" number, that is shown in the tab. Then, go to the fluent terminal and type: "mesh" then "modify-zones" then "make-periodic". Follow the instructions. Fluent will then delete one of the zones an the other one will be left under "Cell Zone Conditions". If you click on that surface a "periodic conditions" button will appear, where you can set up things such as pressure drop along the periodic zones.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   April 24, 2013, 06:33
Far
Sijal
I showed in one the posts that you can output one periodic boundary condition in ICEM to Fluent easily (your case has single periodicity) and whereas for double periodicity you should define one in ICEM and other in Fluent
Ok found it Double periodicity in Fluent
Here we go for more
ICEM periodicity specification
FLuent simulation of taylor couette flow of concentric cylinder geometry.
Specifying Periodic Vertices Causes Mesh Overlap
Old   April 24, 2013, 07:10
christine
Oups, quite hard to understand...I look at it now.
In the meantime, I've generated the mesh from your file and this time, Fluent could read it. But as for the other parts, the periodicity is set to translational.
So I tried to do what Rodriguez wrote, but the strange thing is that when imported in Fluent, I have just 1 periodic surface, no shadow, so maybe Fluent just see 1 surface instead of 2 and that's why he puts directly an angle of 0 when I tell him to use rotational. mean, if considering your file, in Fluent, I just have per1, no per2, but on the display, when I clic on per1, I have the 2 surfaces (Fluent puts per1+per2 in per1)
Old   April 24, 2013, 08:20
Far
Sijal
This is how periodic works in Fluent. You will have only one entity for two periodic surfaces .
Old   April 24, 2013, 08:30
christine
I really don't understand: I've created a part with NO PERIODICITY (no periodic mesh, no vertex periodic...no boundary condition with periodicity in ICEM)... but it's not read in Fluent and I've a message telling that 2 zones have inappropriate zone type (periodic)...but I didn't specify ANY periodic zone in ICEM !!!
I'm getting really mad now.
christine
but so, how do I give Fluent the 45 degree value?
Old   April 24, 2013, 08:31
Philipp
Did you free all the points in ICEM from beeing periodic? Did you recreate the premesh and re-convert to unstructured mesh?
Old   April 24, 2013, 08:42
christine
yes I did.
But the names of surfaces were "periodic_dx" and "periodic_sx", I didn't change that...they are just...names...but this time, I named them : "titi" and "toto"...and Fluent read them as separate surfaces (maybe putting the word "periodic" in the name gives automatically to Fluent the "idea" of periodicity ), no problem for check grid...WUNDERBACH :-) .... but impossible to create the periodicity in Fluent, following your advices....
sorry if you already read that post : ok for periodicity, I just forgot to change the axis in Fluent. It's ok now. So, it seems that a name shouldn't contain "key" words. But why do I have to do it like this? Periodicity in ICEM should be ok!
Old   April 24, 2013, 08:44
Far
Sijal
If you want to specify it in Fluent via TUI, Fluent should automatically determine angle
Old   April 24, 2013, 09:00
christine
yes, he did it :-) (45 degrees)
But I still don't understand why I have to cancel all periodicity in ICEM. Isn't there any risk that creating mesh in ICEM with no periodic conditions, leads to an "non-periodic" mesh? I mean, a mesh that would not correspond cell by cell on the 2 surfaces?
Old   April 24, 2013, 09:02
Far
Sijal
Yes it should do as want to do. But for that you need to understand how ICEM periodic function works. You have to specify that at two places. One in mesh panel and second in blocking (making all corresponding vertices periodic)
Old   April 24, 2013, 09:03
Philipp
As far as I understand it, you have to ensure that by yourself. Also, I think that marking nodes as "periodic" won't do that for you. But maybe I am wrong.
ps: great that you did it!
Old   April 24, 2013, 12:44
christine
hi Far, Rodriguez,
well, about periodicity in ICEM, except the fact that I was using the "user defined by angle" instead of "vector", where am I wrong?
I was doing this:
Mesh/Global Mesh Setup then set-up periodicity
Blocking/Edit Block , then Periodic Vertices (selecting the pair of periodic vertices, respecting the same orientation each time)
Output/ Boundary Conditions , then giving periodic to the periodic surfaces
you're right Rodriguez, I'm happy it's quite done, but it's not automatic to cancel the periodic vertices, sometimes when doing Pre-Mesh and loading the mesh, everything is going wrong...so I have to cancel blocking and do it again....taking a lot of time.
The good point is that I'm learning a lot like this.
Another question, when doing block, the points and curves must not be included really? only surfaces and body? maybe I'm wrong with this from the beginning.
Thank you so much to all of you; I wouldn't have done it without you. It's not completely finished, but I hope big problems are over now.
Old   April 24, 2013, 13:12
Far
Sijal
hi Far, Rodriguez,
I haven't used it lately. But difference is that with user defined angle, it is assumed that you have axis of rotation is on any three of principal axis. So if you have offset then you cannot use it. Instead use "vector option and choose two points which lies on axis of rotation.
Just cancel the periodicity in the same panel where you have created.
For 3d case, you just need surface for boundary conditions and material for interior. For 2d case you need curves for boundary conditions and no need of material (or body) for interior.
Old   April 29, 2013, 05:42
christine
Hello again !!!
I've meshed all the different parts, merged everything in Fluent. It was ok, but when running simulations, results were really strange, I think I had too many interfaces. So I've been trying to mesh again in 1 piece... I've done it maybe 10 times!!! and everytime, there is something wrong.
I send you the last try. Could someone tell me why the mesh is coming like this (at the upper right "corner" ) ? sometimes, this part comes ok but with other problems and sometimes not. I always do the same thing so I really don't understand.
Old   April 29, 2013, 06:07
Philipp
Hi, there is a .zipx file inside the zip file. Can you uplaod a "common" file format? Such as just .zip ?
Thread Tools
Trackbacks are On
No layers in a small gap bobburnquist OpenFOAM Native Meshers: snappyHexMesh and Others 6 August 26, 2015 09:38
[ICEM] ICEM Structured Mesh Problem OMJT ANSYS Meshing & Geometry 3 March 22, 2013 11:06
CFX Mesh Deformation problem Silmaril CFX 7 October 19, 2010 10:00
Dynamic Mesh Problem. Tom Clark FLUENT 9 July 7, 2010 07:56
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
