April 29, 2013, 06:26 |
#61 |
christine
Rep Power: 16 |
the file is too big if *.zip, how else can I send it?
April 29, 2013, 11:34 |
#62 |
christine
Rep Power: 16 |
ok, I've tried AGAIN.
Now I have another problem of "Cell Centroid is xc 35.776754 yc 6.767326 zc 0.400559 WARNING: no face with given nodes. Thread 16, cell 10995" I read on-line that it could be a problem of meshing. So I opened again the file and got what is on the picture !!! what is it???? I don't know anymore what to do with ICEM !!!! Everytime I have a different kind of error. Are there some bugs or I don't know? |
April 29, 2013, 12:38 |
#64 |
christine
Rep Power: 16 |
what do you mean? what do all these blue lines mean?
April 29, 2013, 14:39 |
#66 |
christine
Rep Power: 16 |
I have just done Y-blocks for the part down the geometry and the upper-right part. I have done that maybe 30 times, always starting from the geometry (not canceling existing blocks) and it is the first time I get that.
I am really getting mad. It's been exactly 2 weeks I've been trying and I know now that everytime, I will have a different error (interior parts seen as wall, error on cells without mesh like the previous one, mesh not read for I don't know which reason...). |
April 29, 2013, 15:35 |
#67 |
Quality > 0.8
Angle > 45 I didn't check it in fluent. Just finished blocking and uploaded here. Please check blocking and let me know if something is missing... https://dl.dropboxusercontent.com/u/...nozzle_Far.zip |
April 29, 2013, 16:13 |
#69 |
christine
Rep Power: 16 |
Thank you very much for this!
I see that I was doing wrong with my Y-blocks. There were 2 problems when I generated the mesh, maybe because I have not all the files. For one it was ok, I could fix it. For the other, I send you a picture of it. And I was wrong also since I was trying to avoid the small cells (coming from the beginning) all through the chamber. |
April 29, 2013, 17:13 |
#70 |
Corrected files...
https://dl.dropboxusercontent.com/u/...-2013_Far2.rar PS: Wait at least one hour so that files get uploaded on dropbox. |
April 29, 2013, 17:52 |
#71 |
christine
Rep Power: 16 |
I can't get the files, I have :
Error (404) We can't find the page you're looking for. Check out our Help Center and forums for help, or head back to home. |
April 30, 2013, 02:45 |
#73 |
Philipp
Rep Power: 26 |
Far, in this triangle shaped geometry, where you have the three blocks: Is there a way to tell ICEM to make the angle of the three edges in the middle equal (each 120°)? Or do you have to estimate it by hand?
The skeleton ran out of shampoo in the shower. |
May 3, 2013, 03:42 |
#75 |
christine
Rep Power: 16 |
Hi Far,
sorry for replying so late but I had to work on something else. I'm now back on this job. Thank you very much for what you have posted. There is just a problem with periodicity. I've "rebuild" the parts (lato_sx and lato_dx) but the problem remains. So yesterday, AGAIN, I tried by myself and this time all was ok, at least, it seemed. Fluent read without problem, ok also for periodicity, but I encountered a new problem (!!!). I send you the picture. When I go back to ICEM, in the menu on the left, under mesh, I have some shells and the problem seems to be there. However I'm running the case with Fluent and it seems ok but I don't know if the results will be influenced by this...the problem lies at the main inlet : the inlet mesh takes a part of the wall mesh, the wall-ogiva takes a part of wall-inlet...I don't know why I have this situation. When running the case, I import profile at the inlet, so, only cells in the profile are concerned, so maybe the calculations can be ok, but still....why? |
May 3, 2013, 05:16 |
#77 |
christine
Rep Power: 16 |
well, maybe I was not really clear in my explanations :-)
the inlet should be just the vertical "blue" part and in fact, when displaying it, I also have a part of the wall. |
May 3, 2013, 12:23 |
#78 |
delete that block only.
create new block with eight vertices. four are there, and click on four locations approximately. Associate edges to curves and vertex to point and you are done. |
May 3, 2013, 14:26 |
#79 |
christine
Rep Power: 16 |
ok, I'll try that, I'm just afraid that maybe the face between the 2 bocks will be seen as wall in Fluent, already had this problem ... I'll tell you
Thanks again! |
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 04:27 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] ICEM Structured Mesh Problem | OMJT | ANSYS Meshing & Geometry | 3 | March 22, 2013 10:06 |
CFX Mesh Deformation problem | Silmaril | CFX | 7 | October 19, 2010 10:00 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
