[ICEM] What is the reason for this negative determinant?
Old   January 25, 2013, 11:05
Default What is the reason for this negative determinant?
Ye Zhang
kiddmax is on a distinguished road
Hello,guys.
Now I want to simulate the flow over wind turbine rotor, but when I am doing the mesh, there is a problem that says negative determinant when I check the mesh. you can see the bad cells(green) in the picture. so I want to know what is the reason for negative determinant and how to improve the bad cells? Thank you in advance.
Regards
Ye
kiddmax is offline   Reply With Quote
Old   January 25, 2013, 11:40
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
sometimes a simple update of the blocking can solve the problem.
best way to track those element is by using the scan edge or cut plane...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 25, 2013, 12:28
Ye Zhang
Hi, M.Ali
Thank you for your reply.
I can track(see)the bad cell, what I don't know is how to improve it? The green cells that have negative determinant looks quite triangle, right? but after the sharp trailing edge, I have get two blocks, is this the right method to deal with sharp edge?
regards,
Ye
Old   April 18, 2013, 09:59
Catthan is on a distinguished road
kiddmax have you found a way to sort this?
I'm having the exact same problem with a sharp edge.
The geometry and even the histogram look frighteningly similar too,,
Let me know.
Best,
Catthan is offline   Reply With Quote
Old   April 18, 2013, 10:13
Ye Zhang
Hi, Catthan
What about your blade? is it 3D or 2D?
I advice you to use C grid for the sharp trailing edge. This is a tutorial on youtube.
http://www.youtube.com/watch?v=mgjRT4WY_iA
and make sure to use a block for "boundary layer", that will be much better.
just like this
Old   April 18, 2013, 10:15
Ye Zhang
this is the picture
Old   April 18, 2013, 10:59
diamondx's Avatar
Ghazlani M. Ali
scan plane and cut plane are the best tools to look for thoe negative elements...
Regards,
Ali
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
