[ANSYS Meshing] 2D canard geometry inflation error
Old   May 28, 2017, 03:52
Default 2D canard geometry inflation error [Unsolved]
Alex
alaspina is on a distinguished road
I am meshing a 2D canard main wing geometry with a symmetrical airfoil. I construct the mesh via the meshing tool. I have a rectangular region of a hard mesh of small element size between the canard and main wing. I define an element size for the canard and main wing surface, as well as a sphere of influence for even more accuracy that extends to to 10% the chord length of the main wing and canard (two different sphere of influences placed at the center of each wing). I then set a total layer thickness for the main wing- very good stuff. But then i get this error when I do the same for the canard-
Shell inflation failed, possible due to edge imprinting or connecting the inflation mesh to the rest of the mesh. Please try to reduce the total height of the inflation layers and see if that helps. I will post progress here if any. Any help is appreciated.
alaspina is offline   Reply With Quote
Old   May 29, 2017, 00:10
Alex
Ive managed to make it work by removing the element size sizing on the canard surface. Still not sure why the smaller geometry affects this and it decreases the structural accuracy of the mesh outside the boundary layer.
Sent from my Moto G (4) using CFD Online Forum mobile app
Old   May 30, 2017, 23:32
Alex
Bump. Still looking for a better method
Old   June 4, 2017, 06:19
Alex
Not much progress still. Really curious as to why this happens. Any help is appreciated
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
