April 21, 2013, 04:57 |
Wing Inside Cylindrical Domain. Block Strategy
Javi
Hi guys,
As some of you know, Iīve opened some threads asking some ideas for mesh a wing in a cylinder. I want to say too, thanks to you guys, I can improve faster in a lot of ICEMīs facets. Hence, I want to share with you what I believe can be one solution of this problem. I supposed, a lot of you can, think and do, the blocking strategy in 5 minutes but for beginers like me, maybe, it can be useful. For that reason, I want to share with you the steps and, if it's possible, I would like someone respond my final doubt about other approach Iīve done. I would like to say too, that this approach is the fruit of mix Simonīs video approach (http://www.youtube.com/watch?v=EknKVAJGEJ8) and O-grid's phylosophy. 1- Create Block around the geometry. 2- Create O-grid. 3- Create a second O-grid. Last edited by FJSJ; April 21, 2013 at 10:04. |
April 21, 2013, 05:00 |
Javi
4- Split block like picture 1
5- Move vertices to get visual space 6- Associate edges to curves 7- Collapse block behind wing |
April 21, 2013, 05:02 |
Javi
8- Split block
9- Merge blocks 10- Merge vertice 11- Delete block inside wing 12- Move vertices for better quality |
April 21, 2013, 05:03 |
Javi
Here the last pictures. Iīve tried to describe in detail as much as possible.
Anyway, like Far said in [ICEM] Structured Hexa Mesh on Wing "... for wing with sharp trailing edge, the best domain is circular (hemisphere in 3d) shape at inlet and rectangular at outlet (cylinder)" Making this approach I can understand better this statement. http://www.youtube.com/watch?v=WT1S0e6mCD4 Last edited by FJSJ; April 21, 2013 at 06:42. |
May 30, 2013, 03:59 |
Javi
Thank you Far!!
cylinder domain, wing |
[ANSYS Meshing] block strategy | yorelchr | ANSYS Meshing & Geometry | 11 | December 13, 2012 10:57 |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 10:01 |
ICEM meshes inside my wing | LBRS | Main CFD Forum | 6 | February 21, 2008 09:09 |
block geometry inside fluid domain | jeff | Main CFD Forum | 18 | April 12, 2004 11:37 |
contours with block inside. | Paul | Main CFD Forum | 0 | November 20, 2000 04:20 |
