Home > Forums > ANSYS Meshing & Geometry
[ICEM] cannot import to FLUEN
Old   April 22, 2013, 09:07
Default cannot import to FLUEN
tita
ok___ko is on a distinguished road
HI, everyone.
When import my mesh from ICEM to FLUENT, the window says:
'Error: This appears to be a surface mesh.
Surface meshes cannot be read under the /file/read-case functionality.
Reading Cells: failed while reading section 12.
Clearing partially read grid.
Error: Read_Grid_Section: Aborted due to critical error.
Error Object: #f
Error: Error reading "Z:\CFD 2\ICEM parts\fluent.L=H.msh".
Error Object: #f'
Does anyone know why? How could I do it?
ok___ko is offline   Reply With Quote
Old   April 22, 2013, 13:18
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
weird. it is like you don't have 3d element (volume mesh) inside. did you assign a boundary condition of "fluid" in the output menu ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   April 22, 2013, 14:41
tita
No, I haven't assign a boundary condition of "fluid" in the output menu, do I need to do this? Or could I edit boundary conditions in the FLUENT?
And this is a 2D mesh.
Thread Tools
Trackbacks are On
[Workbench] DesignModeler & mechanical import Mehdi41 ANSYS Meshing & Geometry 9 August 1, 2016 11:04
I developed an FEM toolkit in Java: FuturEye nkliuyueming Main CFD Forum 7 January 29, 2016 14:28
Import transient cfx-results for static structural analysis in Ansys WB 13 Colt Seavers ANSYS 1 August 11, 2011 06:01
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
import 3D I-DEAS mesh in Fluen Francesco Di Maio FLUENT 0 January 27, 2005 12:16
