[DesignModeler] Equation Driven Curve - URGENT
Like Tree1Likes
  • 1 Post By daysley
Old   April 23, 2013, 08:03
Exclamation Equation Driven Curve - URGENT
sam daysley
daysley is on a distinguished road
Hi Again
I wondered if anyone could give me any help with ansys design modeler please. my problem is i need to create an equation driven curve for an airfoil/ hydrofoil then use optimisation to optimise torque on a vahkt. firstly i have no idea where to find an equation driven curve in designmodeler (ive tried to parameterise splines, lines but no luck).
however, i have modeled the geometry in solidworks, created a surface and imported the geometry into workbench but my parameters are not exported and the airfoil is orientated incorrectly??
basically all i want is a 2d curve that i can interchange with my existing fixed Naca00xx profile and run an optimisation sim
any help is greatly appreciated, thanks in advance!!
Sam
daysley is offline   Reply With Quote
Old   April 24, 2013, 12:54
sam daysley
Anyone?
i have imported geometry dimensions today but my equation for the equation driven spline in Solidworks is not showing up which is a bit useless because that's what i need
any help is great
thanks in advance
Old   April 29, 2013, 04:32
Dr. Moloy Kumar Banerjee
moloykb is on a distinguished road
use the 3D curve feature to generate the curve
moloykb is offline   Reply With Quote
Old   April 29, 2013, 05:42
sam daysley
thanks for the suggestion Moloy, unfortunately the 3d curve requires point selection or a coordinate files, whereas i was looking for a curve driven by a parametric equation so i could alter the thickness and camber through the parameters.
I found a work around in the end,
In Solidworks i created the equation driven curve then in a sketch (not in global variables>this is done by dimensioning construction lines) i dimensioned the variables i needed (thickness ratio and chord length) and used the prefix DS_ in the name box. this allowed me to use these values for the curve equations and also import them and indirectly change the equation of the curve from Workbench.
pretty disappointed ANSYS doesn't have the technology to do this unless i haven't come across it yet, but this was a successful alternative hope it helps others in the future.
Thanks for your help Moloy
Seyma likes this.
Old   April 29, 2013, 05:58
Far
Sijal
I am also learning DM, but I have an idea. you can try scripting ...
Old   April 29, 2013, 06:00
sam daysley
Far, i don't think i am familiar with scripting? is this a difficult approach?
Old   April 29, 2013, 06:09
Far
Sijal
definitely coding (even simple scripting) needs more effort... But I am sure you can learn it
Old   April 29, 2013, 09:33
sam daysley
I'll have to have a look into scripting and coding then see where i get, thanks Far ill see how i get on
Old   February 27, 2014, 10:54
federico
fedefrance is on a distinguished road
Hi Daysley,
I have the same problem you have. I would need to perform an optimization of a 2D aerodynamic profile and I would like to use a prametrized curve, like a B spline or a Bezier curve.
I was thinking about inserting the curve by scripting into design modeler or ICEM but I don't know from where to start.
Do you have any suggestion? Did you manage to solve your problem?
fedefrance is offline   Reply With Quote
Old   March 3, 2014, 14:42
sam daysley
Originally Posted by fedefrance View Post
Hi Daysley,
Hi fedefrance
this was what i hoped to do also, however i had no experience with python so decided scripting wasnt the way i was going to go. instead i used solidworks to fully parameterise an equation driven curve and then export the variables (such as chord, thickness etc) to ansys using the prefix DS.
see here for details
https://forum.solidworks.com/thread/64546
you can then import this geometry into designmodeler. this is the only approach i found that worked well, but only allows symmetrical naca profiles to be used. unsymmetrical ones may take a little playing around equation wise, but they could work??
hope this helps
Old   March 4, 2014, 05:44
federico
Hi Daysley,
Thank you for your suggestion, I will give it a try. Also I found another approach which could work:
http://www.youtube.com/watch?v=6wQPeBpvwCk
curve, designmodeler, fluent, parameters, vawt
[ICEM] Smoothing a curve lost.identity ANSYS Meshing & Geometry 6 July 13, 2009 05:23
Need help:about energy equation in CFX Stein CFX 4 July 2, 2009 22:31
URGENT: Divergence in equation AdN FLUENT 0 April 20, 2006 03:27
Boundary conditions in a Poisson's equation? vincent Main CFD Forum 4 April 16, 1999 02:19
