[ICEM] Meshing problem in Formula one
Like Tree3Likes
Old   December 25, 2012, 05:19
Default Meshing problem in Formula one
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I am working on meshing of formula one with simplified geometry. Geometry consists of:
1. Tyre
2. Three wings
3. Four zero thickness plates.
I am successful in meshing the domain with octree and then deleted volume meshing and proceed with denauly (Tglid and AF). But I have problem when I turn on the prism option in volume meshing.
What do you suggest? Should I use Tgrid for volume meshing for good quality of prisms?
Far is offline   Reply With Quote
Old   January 11, 2013, 23:55
Far
Sijal
Now I am able to get the required meshing through patch dependent method but still facing few problems. I will describe them later in next post. But my question is that why I have to set many parameters to get this mesh, which on the other hand is very simple to make in Gambit!!!
I have few questions:
1. How to get working the octree method to get this sort of meshing on the surfaces? Which parameters need to be set and I am really confused in this area?
2. Why there is difference in patch independent and patch dependent shell meshing? May I know the backgroud algorithm?
3. I also think that user/help material should be improved. Something like Ansys meshing or gambit help material
Old   January 12, 2013, 00:14
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
a lot of people tend to delete the volume mesh and replace it with delaunay. while generating a delaunay on the octree mesh is a better approach as it give better results. this is an interesting thread anyway. may you share the geometry see what you did to it ? that picture is not enough for me...
I'm about to have some rest, i'm coming back here tomorrow morning
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 12, 2013, 01:38
Far
Sijal
Ali
I also tend to use this method for volume meshing.
But I am wondering about the surface mesh (aka shell meshing). As you know ICEM gives you two methods to make the surface mesh:
1. Octree method that is top down method. Delete the volume meshing. Smooth surface mesh and fill the volume using the Denauly method. But here two problems arises:
a) surface mesh has problems and even using the edit mesh tools, I am not able to rectify them.
b) Need to set the complicated set of parameters. And I dont understand them. Hope to get them one day
2. Surface meshing and denauly meshing. That is bottom up approach. Here ICEM provides two options to get the surface mesh
a) Patch dependent
This is working now. But always get the problem in innder region while the mesh at the boundary is fixed through curve mesh parameters. I am also using the following options:
i) respect line elements (is this necessary?)
ii) protect boundary elements
iii) project to surface
iv) adpat mesh interior (affected by surface mesh parameters and succesfully used it in this model. Got idea from the one of the Simon's post)
v) Try harder 1 and some times 3. But dont see any effect in current method
b) Patch indepdent
This method prodecues the different mesh, mesh density and have problems on the surface. It is simply now following surface. Why this method is produceing the differnt mesh than the patch dependent if one patch is being meshed at a time.
Old   January 12, 2013, 09:07
cfd seeker is on a distinguished road
Octree method uses Patch Independent method to project the volume mesh on the surface. Generate the surface mesh first using Patch Dependent method and then filling the volume with Delaunay if you dont want to use PI surface mesh
cfd seeker is offline   Reply With Quote
Old   January 12, 2013, 09:11
Far
Sijal
but how the patch independent and patach dependent shell meshing work? I am experimenting this on the single patch (one surace) so the mesh should be same? Right? But it is not.
Another side is that if I make the octree mesh, will I get the same surface mesh on that patch, which I am getting through patch indepent shell meshing?
Old   January 12, 2013, 10:40
I do not know the algo behind the two methods but you cannot get the same surface mesh with both. Patch independent dont respect the nose distribution on the curves while Patch dependent does respect
I guess so
Old   January 12, 2013, 11:23
Far
Sijal
I guess so
PI also respects the node distritubatin on the curves, if it is asked to do so
Old   January 12, 2013, 11:30
I am confusing blw the two but one respect and one does-not.....
Old   January 12, 2013, 11:58
Far
Sijal
Patch dependent is designed to mesh using the curve info. While PI by default does not so. But if we turnn on the option "respect line elements" then it does so.
Old   January 12, 2013, 13:55
diamondx's Avatar
Ghazlani M. Ali
https://www.sharcnet.ca/Software/Flu...algorithm.html
can you provide the tin ...
Regards,
Ali
Old   January 12, 2013, 13:58
Far
Sijal
All surfaces and edges are recreated in ICEM
https://dl.dropbox.com/u/68746918/project22.tin
Edit : Link will work after about one hour (very very very slow net. With 1 MB connection I am only getting 4 kbs uploaded speed. Shared internet service provider )
Old   January 12, 2013, 14:01
diamondx's Avatar
Ghazlani M. Ali
link is not working or may be upload is not yet done
Regards,
Ali
Old   January 13, 2013, 10:48
Far
Sijal
I am working step by step and therefore progress is very slow.
These are my observations :
1. Good geometry is important
2. I need to set the many local parameters along with the curve parameters.
I have one query here:
The common curve between two surfaces should be part of which surface ? Surface 1 or 2? or Both (how is that possible?) ? If I dont build the topology then I have to create the one curve for each surface! In this case how to define the curve parameters?
Old   January 13, 2013, 11:11
diamondx's Avatar
Ghazlani M. Ali
It was easy to generate beautiful surface meshes in your geometry because of the quality of it. your curves and surface are well defined. where did you make them ??
So you are filling up later with volume mesh ?
Tomorrow i will share with you one more complex geometry, not complex but you will see how it's difficult for ICEM to generate a surface mesh while the geometry is a simple cylinder. i guess it because of its quality
Regards,
Ali
Old   January 13, 2013, 11:17
Far
Sijal
I had to recreate the each and every point, curve and surface in the ICEM. Before that I had many problems in both methods (octree or surface meshing).
Yes later I will fill the volume with danualy. I am also thinking to take the surface mesh to Tgrid and make the further process there... What do you say?
Old   January 13, 2013, 11:21
Far
Sijal
did you play with the surface mesh parameters? It is very much important to play with global parameters, surface mesh parameters and curve mesh to get the good surface mesh. Things are more complicated in ICEM for some purpose which now I am getting. The purpose to provide more control but it makes things more complicated for novice like me....
Old   January 13, 2013, 11:23
diamondx's Avatar
Ghazlani M. Ali
i had never used tgrid !! how about the prism ??? is there a tutorial on how to do that in tgrid ?? is tgrid better than using the tgrid approach when using delaunay in icem ??
Regards,
Ali
Old   January 13, 2013, 11:26
diamondx's Avatar
Ghazlani M. Ali
yeah i tried every single parameter from autoblocking to delaunay !!! surface was not successful because of the geometry. you need to define thin cut between the tire and the ground...
Regards,
Ali
Old   January 13, 2013, 11:29
Far
Sijal
Check out the power of Tgrid here:
https://dl.dropbox.com/u/68746918/AN...st-edition.zip
Yeah I have tried them all. But you need to define many other parameters in global mesh settings, shell meshing setting, surface part mesh setting and ........
No I don't need to define thin cuts for groud and tyre. I need to define thin cuts for the zero thickness plates (which are not shown here)
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 18, 2023 23:49
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 07:21
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
[ICEM] Hexa meshing blocking problem fergal ANSYS Meshing & Geometry 0 June 28, 2011 10:01
Strange ANSYS Meshing 13.0 Problem brunob ANSYS Meshing & Geometry 3 June 21, 2011 20:03
