Problem with periodicity
1 Attachment(s)
I'm having a problem with defining periodicity in my geometry. My geometry is very simple, you can see it here: Attachment 21092 It's a part of the Tesla's rotor. I consider only 1/10 of the rotor, so in the Global Mesh Setup->Set up Periodicity I've set the base at (0 0 0), the direction of the axis of rotation (0 0 1) and the angle 36 degrees. And some info about the volume meshing parameters: mesh type: tetra/mixed mesh metod: Robust When I'm trying to generate mesh I get the following error: Quote:
Dear Zyryx, do you still face the problem? Since your geometry is that simple, why don't you use hexa/structured meshing? What do you use for solving?
