April 24, 2013, 09:43 |
Problem with periodicity
#1 | |
Sebastian
I'm having a problem with defining periodicity in my geometry. My geometry is very simple, you can see it here: geom.jpg It's a part of the Tesla's rotor. I consider only 1/10 of the rotor, so in the Global Mesh Setup->Set up Periodicity I've set the base at (0 0 0), the direction of the axis of rotation (0 0 1) and the angle 36 degrees. And some info about the volume meshing parameters: mesh type: tetra/mixed mesh metod: Robust When I'm trying to generate mesh I get the following error: Quote:
April 29, 2013, 08:43 |
Philipp
Rep Power: 26 |
Dear Zyryx, do you still face the problem? Since your geometry is that simple, why don't you use hexa/structured meshing? What do you use for solving?
The skeleton ran out of shampoo in the shower. |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
radial inflow turbine rotor periodicity problem | Nanda | FLUENT | 1 | July 17, 2006 14:52 |
radial inflow turbine rotor periodicity problem | Nanda | FLUENT | 0 | July 11, 2006 20:35 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
