Home > Forums > ANSYS Meshing & Geometry
[ICEM] Meshing of a UAV
Old   April 25, 2013, 11:27
Question Meshing of a UAV
Ibrahim
IbrahimSher is on a distinguished road
I have a UAV to mesh. The problem is that the geometry is imported from Pro E and is assembled from a large number of surfaces. Now here's the question should I make the whole, say, wing a complete faceted surface or leave as it is and generate mesh.
IbrahimSher is offline   Reply With Quote
Old   April 25, 2013, 13:22
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
Your question is not clear. You want mesh on your model?
For external flow you should make the enclosure. It can be of any shape cylindrical, sphere, hemisphere in front and cylindrical in rear or rectangular.
Far is offline   Reply With Quote
Old   April 26, 2013, 00:37
Default Mesh
Sam
sameben is on a distinguished road
I think it depends on which software you would want to mesh, more patches would involve in generation of more connections, more blocks and more time. Converting it to a faceted one should alleviate most of the problems.
sameben is offline   Reply With Quote
Old   April 26, 2013, 08:45
Ibrahim
I am using Ansys ICEM. As you know Pro E files are read as splines in ICEM converting those to faceted would not cause any inaccuracy? Secondly I'm thinking about unstructured mesh generation not the structured using blocking.
Old   April 26, 2013, 09:41
Default Patch Independent algorithm
Far
Sijal
There you can use patch independent option. So no need to make faceted geometry?
Do you have an idea that how would you convert your geometry to faceted?
Old   April 26, 2013, 09:50
Ibrahim
Yes! you do it by merging surface option!
Old   April 26, 2013, 09:53
Far
Sijal
Any how you should use patch independent option to make mesh for the geometry where there are too many surfaces and having small gaps as well.
I can send you some tutorials on that or you can find them in help menu of ICEM.
Thread Tools
Trackbacks are On
[ANSYS Meshing] Can I use ANSYS Meshing for manual meshing? Kirjain ANSYS Meshing & Geometry 6 November 30, 2015 09:11
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 06:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
