Home > Forums > ANSYS Meshing & Geometry
[ICEM] Mesh generation
Like Tree4Likes
  • 1 Post By Far
  • 2 Post By stuart23
  • 1 Post By noorul
Old   April 26, 2013, 08:57
Default Mesh generation
Noorul Huda
noorul is on a distinguished road
hello..
i have to do a simulation over a pleated insect wing. i'm using ICEM CFD 14.0 for mesh generation. when i select Robust Octree as mesh method, mesh is easily created. for more smooth transition when i select Delaunay as mesh method, no mesh is created. i have tried so many times. please help me out.
Thank You..
noorul is offline   Reply With Quote
Old   April 26, 2013, 09:47
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
For denauly you need surface mesh.
So you should do like:
1. Set mesh sizes
2. generate octree mesh
3. Delete volume mesh
4. smooth surface mesh
5. Now compute danauly mesh.
Far is offline   Reply With Quote
Old   April 30, 2013, 13:44
Noorul Huda
Thanks a lot Sir..
i tried so many times, but the problem remains there.
however I succeeded in generating delaunay mesh over simple geometries like 3D circular cylinder etc.
i think very small thickness of my wing might have something to do with this problem.
Please suggest me what to do now..??
I have attached a image showing a series of thin pleated wing sections i have used to create the wing surface..
Thanks once again..
Old   April 30, 2013, 18:21
Far
Sijal
is this a image of your wing or you will skin all these tubes to make a wing surface?
noorul likes this.
Old   April 30, 2013, 19:08
Stuart Buckingham
stuart23 will become famous soon enough
For Patch Dependent surface meshing, you need to have well connected topology. First run build topology and ensure that all of your curves turn red.
sandy_1982 and noorul like this.
http://bc247.wordpress.com
stuart23 is offline   Reply With Quote
Old   April 30, 2013, 22:14
Noorul Huda
Sir I have created a surface as shown in the image.
Old   April 30, 2013, 22:17
Noorul Huda
Yes Sir, I have taken a tolerance value of 0.1 and ran the build topology. All my surfaces are with in tolerance and curves turned red.
sandy_1982 likes this.
Old   May 3, 2013, 10:41
Sajin
Sanju is on a distinguished road
Hello....I'm new to CFD. I want to know what is the advantage of delaunay over octree mesh. Why we are going for delaunay?
Thanks
Sanju is offline   Reply With Quote
Old   May 3, 2013, 12:22
Far
Sijal
Actually octree is robust method, means you don't need any surface mesh and it rarely fails to generate decent mesh. But problem with octree is that if will make mesh where:
1. Where size change is abrupt i.e growth is not smooth
2. No of nodes are too high.
While with denauly you have smooth transition in volume mesh.
So best option is to generate volume mesh with octree, delete volume mesh and leave surface mesh, smooth surface mesh and compute denauly.
There are many threads where Simon discussed both methods in great details.
Meshing problem in Formula one
Old   May 6, 2013, 01:55
Sajin
Sir,
Thanks for the reply.It wud be great help if u cud give me a slight guidance.
In my case I hav to mesh an inducer of a centrifugal pump (similar to the propeller of a ship) and the entry of flow into the inducer is not symmetic like in propeller.
So I cant use a sector of inducer and mesh, instead I hav to use the entire geometry. So which method should i go for?.. hexa meshing or tetra meshing. The number of nodes is also a concern for me and I'm using ANSYS paltform.
Thanks
Old   May 6, 2013, 02:54
Far
Sijal
Sanju, Can you please start a new thread with proper title...
Old   June 21, 2013, 08:43
Default help
  #12
keyhan's Avatar
keyhan
keyhan is on a distinguished road
can any one give a tutorial for a 2d centrifugal pump how to make a mesh and how to analysis in fluent from 0 to finsish plz help,,please send to keyhan_mec@yahoo.com
keyhan is offline   Reply With Quote
Old   June 23, 2013, 02:42
Far
Sijal
divide the domain (blocking) for the mapped meshing and for tetra mesh set sizes on surface/curves and compute mesh.
Thread Tools
Trackbacks are On
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[ANSYS Meshing] Question about mesh generation learning lnk ANSYS Meshing & Geometry 2 July 7, 2012 06:45
ISAAC code mesh generation morteza08 Main CFD Forum 0 June 15, 2012 09:26
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
