[DesignModeler] Circular pattern - Turbomachinery |
April 27, 2013, 05:20 |
I have single blade at the required location and now I am trying to create other blades (total no of blades are 5-12, as it is parametric study).
For this purpose I am using pattern with circular option and following workshop 5a downloaded from ansys website. For tutorial I am successful in creating the circular pattern for the stirred tank example. Fig 1 But I am not successful in making circular pattern for my case as shown in Fig2. Error message is "Error: Operation would result in illegal T surface bodies Context: Geometry Engine, while generating Feature Pattern10" Any idea is welcome and highly appreciated. I am attaching DM file. https://dl.dropboxusercontent.com/u/...n_pattern.agdb |
April 29, 2013, 04:43 |
Freeze the body before you make the pattern and it will work
April 29, 2013, 04:49 |
Ah, again it's due to the bodies being surfaces. Use "Fill" to make a solid, then rotate
April 29, 2013, 04:51 |
jrunsten: I am following your advices and learning DM at good pace.
But i get confused easily in DM while working with surfaces and solids and I always try to correlate it with GAMBIT |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Pattern on football ball | RiKR0K | Main CFD Forum | 0 | March 22, 2010 08:37 |
Turbomachinery at OpenFOAM Workshop Milan 2008 | hani | OpenFOAM | 0 | March 21, 2008 02:33 |
conjugate heat transfer in circular channel | src | FLUENT | 1 | August 6, 2004 07:13 |
