May 1, 2013, 20:44 |
Workbench 14: Mesh Control
dstrunner
I have been a long time user of Gambit and am now trying to jump into the new meshing module in Workbench 14. Is there a way to mesh edges and then have that edge mesh be incorporated into the overall mesh of a surface and/or volume? Likewise, is is possible to mesh a face and then extrude that mesh along a line in order to mesh the volume? I am having trouble with the automesh features and wanted to know if there is a way to exert more control over the mesh generation. Thanks in advance for the suggestions!
May 2, 2013, 02:34 |
Paritosh Vasava
Rep Power: 22 |
On top menu there are icons with which enables selection of edges and faces. Once you press one of the buttons you should be able to select edge or face. Then you right click and insert 'sizing'.
In addition there are option to get mapped mesh and other options to chose from Mesh Control->Method. |
May 2, 2013, 09:05 |
Paritosh Vasava
Rep Power: 22 |
This might also help you. https://www.sharcnet.ca/Software/Flu..._G_MOD8_2.html
mesh, mesh adaptation |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
[ANSYS Meshing] Problem in updating the mesh in Workbench | victorz | ANSYS Meshing & Geometry | 23 | October 31, 2017 03:52 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
