Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Hot to change the O grid in the following pipe
Old   May 3, 2013, 02:11
Default Hot to change the O grid in the following pipe
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
Dear friends:
I use O grid to generate mesh for a ellipse pipe, i not want to change the rectangular edge in the center of the pipe to a circle so as o further improve the quality of mesh.
but how to change the edge in to a circle?
Regards
ztdep is offline   Reply With Quote
Old   May 3, 2013, 02:42
Javi
FJSJ is on a distinguished road
I donīt understand what you mean. Do you want to adecuate the edges to your geometry?
You can edit the edge so you get a edge with the same shape.
Blocking -> Edit edge -> Split Edge -> Automatic Linear.
Then select the edge you want and you get the same shape of the curve.
If you want to use "Automatic linear" you have to "update" before.
FJSJ is offline   Reply With Quote
Old   May 3, 2013, 03:04
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Do you want the inner block to be a cylinder? If so, don't do it. It degrades the mesh at the points of intersection of the edges. That's why you use an O-grid at all - to blend from the outer circle to an inner rectangle.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   May 3, 2013, 05:56
ztdep's Avatar
p ding
yes, i want the inner block to be a cylinder. but i think if it is a cylinder, then we can use a cylindrical coordinate mesh , it is orthogonal. why you say it degrades the mesh?
thank you
Old   May 3, 2013, 06:01
Philipp
Maybe I don't get you right, but can you draw a simple sketch, how you want the mesh to look like at the face?
good:
bad: (not all lines are drawn)
bad, too:
Old   May 3, 2013, 08:49
ztdep's Avatar
p ding
good:
Attachment 21431
Attachment 21432
bad, too:
Attachment 21433
Dear friends:
I merge the four vertices of the inner block, then i get this . but the vertice is not at the center position.
Old   May 3, 2013, 09:10
Philipp
But how do the center cells looks like? It is exactly the same bad shape as in my second "bad"-case: distorted triangles. This isn't hexa any longer and also for tri mesh it would be bad!
Old   May 3, 2013, 16:01
Javi
If you do exactly you said before you get this picture. Iīve moved the vertex to the center of the cylinder and I get this. But...as Phillip said before... you get bad quality elements as you can see in the quality histogram.
Old   May 6, 2013, 03:26
Javi
I would like to know how to do this but with mesh mix. I mean, with hexas and in the center of the cylinder with tri elements. Is that possible? I know in ANSYS Meshing is possible but, can I do it in ICEM CFD too?
Old   May 6, 2013, 03:31
Philipp
I think that works, but I wouldn't do that. I don't see any reason why you would try to get tri elements into a pipe. Hexa elements have the better quality anyway. Especially in pipes, where the flow is orthogonal to the faces most of the time. Also (nearly) everyone meshes a pipe like I show in picture no. 1.
Old   May 6, 2013, 03:59
Javi
Yes, youīre right. I always mesh the pipe in that way. But I ask this, because I need this form to make the mesh. Itīs better to me, to coupling with an turboīs shaft. So, I would like how to do this.
Old   May 6, 2013, 04:05
Philipp
Why don't you just post the complete geometry? That would cause less confusion...
Old   May 6, 2013, 04:27
Javi
I donīt have the geom. Itīs a case that I want to prove. A friend of mine asked me something similar the other day and I didnīt know how to respond to him. So, for that, Iīve asked it here. And because I would like to do a simple case like this mixing meshes.
Old   May 6, 2013, 04:34
Philipp
Alright! Good luck...
Old   May 6, 2013, 05:08
jeevan kumar
jeevankumarb is on a distinguished road
You just merge the 4 vertices of the inside block of O-grid. The you will get what you wanted.
jeevankumarb is offline   Reply With Quote
Thread Tools
Trackbacks are On
[ICEM] Using a hybrid mesh for a simple pipe Udio_NT ANSYS Meshing & Geometry 17 October 18, 2012 14:42
Unstructured grid problem - Laminar flow pipe Roby FLUENT 0 January 12, 2006 06:54
On grid independent solution for pulsatile flow David FLUENT 4 June 8, 2005 16:20
Grid Adaptation Suresh FLUENT 0 October 15, 2003 13:18
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 22:26
