Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] Connection faces-volume
Like Tree1Likes
  • 1 Post By -mAx-
Old   May 5, 2013, 15:42
Default Connection faces-volume
Elena
kalene86 is on a distinguished road
Hi everybody!
I am an engineering student and I’m preparing my master’s degree thesis. I am studying Thermal Energy Storage Systems. In particular I’m focusing on air motion inside a cylinder of porous material. I designed the fluid cell in Gambit ( I have never used this programme before) whose dimensions are 1mmx1mmx500m. In order to get accurate results I inserted 50 sections throughout the volume of the fluid cell.
Can you please tell me how to match each of these faces to the volume?
kalene86 is offline   Reply With Quote
Old   May 6, 2013, 02:50
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
try connect faces
But what is exactly the purpose for inserting those sections?
(if you want later having post-data on those sections), you are not enforce to create them in your mesh.
I would create your parallepiped with 1*1*500 (no unit in Gambit, but scale in Fluent), and you can mesh it on the fly.
kalene86 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 6, 2013, 04:44
Elena
Hi max!
The teacher told me to put these inner sections, so that, in fluent I may know the temperature on them!
Old   May 6, 2013, 04:57
-mAx-'s Avatar
Maxime Perelli
ok, but then you will need to define them as internal (or interior I don't remember) in the BC Panel (else gambit will fuse those sections with the fluid domain)
Again you can also do that later in Fluent with Post-process.
If you want to monitor temperature at each sections DURING the iterations, you can monitor some points.
But anyway if you want to have those sections, you have to connect faces between your volumes.
http://aerojet.engr.ucdavis.edu/gamb...m_face_connect
in the pull down panel "select", choose All
It should connect all the surfaces
The surfaces should appear in pink if "connectivity color based" mode is enabled
http://aerojet.engr.ucdavis.edu/gamb...m#gc_speccolor
Old   May 6, 2013, 04:58
Elena
I'm trying to connect the faces, but the following error:
the call to connect on list on faces resulted in no actual connect operations...
Old   May 6, 2013, 06:22
-mAx-'s Avatar
Maxime Perelli
try with "real & virtual"
Old   May 8, 2013, 06:35
Default error in fluent
Elena
Hello max!!Thanks for your advice.
I solved my problem this way:
I made a face, mesh, extrude with mesh (50 times).
In the boundary conditions i have defined the inner sections as interior.
Now, when I import the file into fluent, after the iteration displays the following error message:
iter continuity x-velocity y-velocity z-velocity energy time/iter
reversed flow in 100 faces on outflow 5.
Error: Floating point error: invalid number
Error Object: ()
Error Object: ()
Error Object: ()
Error Object: ()
Error Object: ()
1 1.#QNBe+00 1.#QNBe+00 1.#QNBe+00 1.#QNBe+00 1.#QNBe+00 0:06:06 2
2 1.#QNBe+00 1.#QNBe+00 1.#QNBe+00 1.#QNBe+00 1.#QNBe+00 0:03:08 1
3 1.#QNBe+00 1.#QNBe+00 1.#QNBe+00 1.#QNBe+00 1.#QNBe+00 0:00:00 0
thanks a lot for your answers!!
Old   May 8, 2013, 06:58
-mAx-'s Avatar
Maxime Perelli
Are your faces all connected? As I said your can check it: the surfaces should appear in pink if "connectivity color based" mode is enabled
Else in Fluent what are the BC listed?
Old   May 8, 2013, 10:32
Elena
Connectivity based color: the color of the faces is MAGENTA!! (Photo)
The boundary conditions are:
input: velocity inlet
output: outflow
exterior walls: wall
internal section: interior
Old   May 8, 2013, 12:36
-mAx-'s Avatar
Maxime Perelli
ok, then try internal instead of interior
If it is not ok, try to merge all your volumes for having no interior.
If is still not ok, then it lies on your BC (you can give your value), but I wouldn't use outflow for outlet. Use pressure-outlet.
EDIT: what gives you a check mesh in fluent?
Old   May 8, 2013, 12:46
Far
Far's Avatar
Sijal Ahmed Memon (turboenginner@gmail.com)
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
-mAx-: Your original idea of making planes, in post processing program where data to be measured, was perfect idea.
Only one need to measure location in gambit to put the location coordinates in post processing software.
Best Regards
Far
http://cfd-consultancy.webs.com/
Far is offline   Reply With Quote
Thread Tools
Trackbacks are On
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 9 May 7, 2013 22:58
non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Native Meshers: blockMesh 7 April 17, 2013 05:42
Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Native Meshers: snappyHexMesh and Others 8 September 13, 2012 09:28
One to one connection for periodic faces Al CFX 0 August 29, 2007 02:34
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
