[ICEM] Volume Generation Problem
Old   May 9, 2013, 01:56
Default Volume Generation Problem
Ibrahim
IbrahimSher is on a distinguished road
There are four attachments with this question
1. Surface Mesh
2. Orfn defined using build topology
3. Boundary Sphere
4. Disoriented volume mesh
How to correct this volume mesh?
IbrahimSher is offline   Reply With Quote
Old   May 10, 2013, 05:39
jeevan kumar
jeevankumarb is on a distinguished road
Did you check the mesh for errors? if there are no errors then the mesher is not able to find a closed body. try to move the material body point inside the domain.
jeevankumarb is offline   Reply With Quote
Old   May 11, 2013, 17:20
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
make sure the body FLUID is outside the plane. you enclosure is not big enough, might give you problem with convergence
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
[ICEM] volume mesh leaking out of the surface, in a multi zone problem premchandpendota ANSYS Meshing & Geometry 6 July 31, 2012 01:36
Negative cell volume problem in-cylinder ziani.lotfi FLUENT 0 April 11, 2012 07:54
[GAMBIT] Gambit - Problem having shadow wall on volume ejvikings ANSYS Meshing & Geometry 3 March 23, 2012 01:30
Ansys 12 Workbench problem when generating volume mesh Sveink ANSYS 5 January 6, 2010 03:17
Star-Design: Volume mesh generation error fusij Siemens 0 November 6, 2009 12:43
