[ICEM] opening fluent .cas file in ICEM
Like Tree1Likes
  • 1 Post By Will Anderson
Old   November 14, 2010, 12:06
Default opening fluent .cas file in ICEM
W.N. Anderson
Will Anderson is on a distinguished road
Why do I see no mesh when I perform "File/Import Mesh/Fluent/" and select a .cas file? The .cas file contains a mesh. But it is scaled (x0.001), so maybe it is too small to see in ICEM? Or is it that I must have a corresponding geometry in order to visualize an imported mesh in ICEM?
Will Anderson is offline   Reply With Quote
Old   November 15, 2010, 14:42
Default Import the Fluent *.msh file
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, you can see and work with mesh all on its own in ICEM CFD. Geometry is not required, but it does make things easier. Geometry can be extracted from the mesh.
But you need to import the *.msh file which actually has the mesh info. The *.cas file is more about the setup, etc.
PSYMN is offline   Reply With Quote
Old   November 15, 2010, 15:18
W.N. Anderson
I was hoping to extract the mesh from the .cas file as fluent had modified the mesh, (dynamic refinement), and i wanted to use the refinements to engineer a new mesh.
The .msh file which i have is the original input to fluent, which i still have in the form of an entire icem project too...
so, importing a .cas file into ICEM won't communicate the mesh to ICEM?
in any case, thanks!
blgypeng likes this.
Old   November 17, 2010, 13:21
Default Cas file should work...
PSYMN's Avatar
Simon Pereira
Oops, my bad... I had personally always imported the msh file and was not aware that we could import cas files also. Even after all these years, I am still learning more about what ICEM CFD can do.
Anyway, I tested some .cas file examples and had no problem with Import Mesh => Fluent and selecting a case file.
So then why are you having a problem? I spoke to the developer (showed her your Post) and she said...
"in general it is possible to import a fluent .cas file into ICEMCFD.
This is either a simple display problem (==> press 'Fit Window' Button), or some other problem with the import reader.
It could also be that this is a bug that is fixed in the meantime (Onyx 109518)."
That particular defect she mentioned was one found on Linux...
Anyway, if you are not just having a simple display problem (user error), we could take a look at your model (confidentially) and see if we could reproduce the problem. Let me know if you would like to try that.
Old   July 27, 2012, 16:46
sa
saharesobh is on a distinguished road
Hope you are doing good. Actually I have the same problem. I cannot see the mesh in Cas File in Ansys Fluent. Would you please give me some advice?
best
saharesobh is offline   Reply With Quote
Old   July 27, 2012, 17:21
PSYMN's Avatar
Simon Pereira
Not quite the same problem... This thread was about not seeing it in ICEM CFD... An ANSYS meshing tool.
If you are having trouble seeing it in Fluent, that is different. Maybe put your question (with more detail since this is not enough) on the Fluent users forum.
Best regards,
Simon
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
Old   May 10, 2013, 03:31
Martin Goddard
McFly is on a distinguished road
Did this problem get fixed?
I too am trying to export a mesh from a Fluent .cas file. As the mesh has been changed within Fluent (with adaption) I need to export the mesh as a .msh file to use in other software.
I cannot open the .cas file in ICEM. It is quite large - about 550MB - does that matter?
McFly is offline   Reply With Quote
Old   May 10, 2013, 05:30
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You can import .cas file in ICEM CFD as Simon had already explained very well.
In essence .cas file contains mesh + boundary conditions + other solver settings so it does not matter whether you have .msh or .cas file. What can matter is RAM (and patience too ) , so if mesh file is large, it will take some time and needs more memory.
Far is offline   Reply With Quote
Old   May 10, 2013, 08:58
Martin Goddard
Thanks for the reply. It must just be my file. I'm getting an error when I try to import it with ICEM.
I will get the exact error code when I am back in the labs tomorrow, and keep looking for answers and/or start a more relevant thread.
Cheers!
Old   May 10, 2013, 14:30
Far
Sijal
One more thing, if directory name is too long it will give you problem. To check whether it is a problem of directory name copy that file to D: or E: and read file.
Old   May 12, 2013, 07:22
Martin Goddard
Thanks for the help. I have got this specific problem fixed (user error) - now I just need to iron out a few other bugs...
Cheers!
Old   May 12, 2013, 08:03
Far
Sijal
Problem solved with above suggestions or it was something else?
Old   May 13, 2013, 01:49
Martin Goddard
It was my fault. I went through everything again with a colleague and found the issue. I have tidied up the directory structure and file names to help with the next phase though.
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
Import data from another .cas file of fluent Umesh FLUENT 1 August 17, 2003 04:51
