[Other] overlapping heat exchanger cores- as in ansys user guide
Old   May 15, 2013, 16:36
Question overlapping heat exchanger cores- as in ansys user guide
Lagunesvary
chinna is on a distinguished road
Hai, thanks for your time...
im simulating heat exchanger using ansysfluent 14.0 and i wanted to use dual cell model. the hot and cold fluid zones are not overlapping and i dont know how to make them.
According to the ansys user manual..
If the mesh file does not already contain overlapping heat exchanger cores for primary and auxiliary fluids, then you must create a duplicate of the zone that represents the core using the following text command:
mesh → modify-zones → copy-move-cell-zone
You will then be prompted to enter the ID of the zone you want to copy, and either the distance for translation in each of the axes or the rotational angle, origin, and axis.
& when i try
modify-zones/: Enter the modify zones menu.
?: Enable help mode. Type "q" to return to command mode
invalid command [copy-move-cell-zone]
/mesh> 13
invalid command [13]
i dont know where`s my mistake. i really don`t have any idea,how to respond the command. can anyone please help me with this...??
chinna is offline   Reply With Quote
Double pipe heat exchanger mohcin FLUENT 21 June 18, 2016 14:19
heat transfer in heat exchanger chinna FLUENT 0 April 4, 2013 13:25
how to modeling heat by fluent and ansys? njiit FLUENT 0 December 9, 2009 00:39
Tube in Tube heat exchanger( But I got error) Young CFX 2 September 26, 2008 01:35
Heat Exchanger...TWO Walid CFX 2 July 11, 2005 19:04
