Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] how to add aonther part in gemotry workbench
Like Tree2Likes
  • 2 Post By diamondx
Old   May 16, 2013, 08:06
Default how to add aonther part in gemotry workbench
Alireza
rasekh64 is on a distinguished road
I want to simulate two cylinders with two bricks inside. one of the cylinder together with brick is stationary and the other is rotary. They are adjacent to each other. To have a better insight, I have attached a section of the problem (the wire frame is selected to show the brick inside). To the present time, I drew only the stationary part. It is required that the rotary cylinder is considered as an another body.
The face split is only for surfaces. do you know other function to do a for volume part?
I would be appreciated if you help me.
Alireza
File Type: jpg Screenshot - 05162013 - 02%3A03%3A38 PM.jpg (40.6 KB, 121 views)
rasekh64 is offline   Reply With Quote
Old   May 17, 2013, 11:39
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
find you a plane, make a sketch and extrude... does it answer your question ? you can also just import it...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   May 17, 2013, 13:39
Alireza
Dear Ali,
Actually the problem was that i didn't active the frozen section while extruding the surface!! it works now. can u plz tell me what freezing a body means in Ansys?!! can it be troublesome in meshing?
Thanks in advance
Alireza
Old   May 17, 2013, 14:55
diamondx's Avatar
Ghazlani M. Ali
From the ansys documentation:
The Freeze feature is an advanced modeling tool available from the Tools menu. Freeze has two applications: it allows for an alternative method for assembly modeling with multiple body parts, and it allows you to "slice" a given part into several sub-volumes (e.g., sweepable volumes for hex meshing).
Normally, a 3D solid feature operates like this:
Create the bodies of the 3D feature (e.g., the body or bodies of an Extrude feature).
Merge the feature bodies with the existing model via Boolean operations:
Add Material
Cut Material
Imprint Faces
The Freeze feature allows you to control the second step. It acts as a separator in the construction history as displayed in the Tree Outline. Any bodies created for features before a Freeze will become frozen. Frozen bodies are denoted by the ice cube icon next to a body under the Bodies branch of the Tree Outline. All frozen bodies will be ignored when it comes to the Add, Cut, or Imprint Material operation of any features following the Freeze.
The solid features offer an additional Boolean operation:
Slice Material
In contrast to Add and Cut, the Slice Material operation is only available when the model consists entirely of frozen bodies. Also, in the case of Slice Material, the Freeze separator does not hide bodies from the Boolean operation.
rasekh64 and thermal energy like this.
Regards,
Ali
Old   July 27, 2015, 11:22
Default Creating separated body parts from an imported geometry
tec
Heather Smith
tec is on a distinguished road
Hi all,
I have imported a geometry from solidworks and it is one body part in ANSYS transient structural. I want to create separated body parts from this geometry (select certain parts of the geometry and create a separated body). Any suggestions on how this can be done?
Thanks
tec is offline   Reply With Quote
Thread Tools
Trackbacks are On
[ANSYS Meshing] Identical meshes in symmetric bodies in multibody part. aarvay ANSYS Meshing & Geometry 2 May 11, 2012 11:15
icem hexa - load different blockings for each part of geometry??? Catthan ANSYS Meshing & Geometry 2 May 28, 2010 11:27
Temperature contour as thermal condition in Workbench? nuothe11th ANSYS 0 April 23, 2010 12:11
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 14:26
Can we add extra solid mesh part to the analsis? Farhath Alam FLUENT 0 December 22, 2006 03:41
