[ANSYS Meshing] problem in using multizone
Old   July 30, 2013, 06:34
Post problem in using multizone
ali
ali92 is on a distinguished road
Thanks for advice ghorrocks.
I have already used tetra mesh, but RMS values are not smaller than 1e-4.
Therefore I want to use hexa mesh. I can see with large hexa mesh my RMS are smaller than 1e-4 and my problem is converged.
If I do not use multizone and use hexa simply with small mesh size,there are meshes with too large size in the center part of my circular conduit.
I can use tetra mesh with body sizing .4m accompanied with multizone, but I can not use smaller size mesh. Error is indicated in following picture:
What should I do?
Please give me some advice!
Best regards.
ali92 is offline   Reply With Quote
Old   July 30, 2013, 06:48
Post
ali
If I do not use multizone and use small mesh size , result is indicated in the picture:
Old   July 31, 2013, 07:33
ali
I can use smaller mesh (.2m) with multizone(Free Surface Type: not allowed) but results are not good.(Water pressure and air velocity are too large )I want to use Inflation but I cannot use inflation. I faced with error.
Which surfaces should be select im my work for inflation?
In multizone:
Which option should be use? Hexa or Hexa/prism.
and which option should be use for Free Mesh Type? not allowed or tetra or Hexa dominant or hexa core.
Which surface should be use for source surface in my work?
Old   July 31, 2013, 07:46
Post
ali
pictures are as shown:
Can every one help me?
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
