change/increase model size box
Hi all)
Is it possible to change in Ansys DesignModeller the "model size box"? According to manual: Quote:
It's done in the dialog box where you select the units during import.
http://i.imgur.com/K8rQGcN.png |
thanks jrunsten!
as i understand it is only possible to do at the beginning. It is not possible to change for an existing project in DesignModeller or? |
To my knowledge, no. You have to do it in the beginning
DesignModeler...Scaling
How to scale model size in Design Modeler. For example, if I select meter scale my model turns to be one meter long.. If I select inch scale it turns to be 1 inch long.. How can I scale up my model to 6 inches..
Thanks |
large model support
before begin drawing the geometry, you should go to tool - options and in the unit section, enable the large model support. be careful: you cant enable this option in the middle of the geometry drawing.
Hope this is useful |
