May 25, 2013, 01:03 |
How to save ICEM CFD mesh in .msh
Harshad Lalit
Rep Power: 12 |
Hello everyone,
I am quite new to ICEM-CFD and want to ask how to save the mesh in .msh format for its use in Fluent. I would be glad if anyone could help out. Thanks a lot! |
May 27, 2013, 11:28 |
E
Rep Power: 13 |
Hello
In the Output tab click on “Select Solver” (the red icon) Then in the Output Solver option find FLUENT_V6 and ANSYS in the Common Structural Solver option. Now click Write Imput, save the project and the open the file with .uns as the extension. A window will appear allowing you to create the .msh file now. Make sure you check Grid dimension and choose the appropriate option for you case. The Output File shows the location of where your mesh file will be saved. You can change the /fluent name to whatever you want your mesh file to be called. Click Done for your mesh file to be saved and now you can read the mesh as a .msh file in FLUENT |
May 27, 2013, 13:00 |
François Grégoire
Rep Power: 17 |
Hi Harshad,
Obviously, you didn't check the tutorials before asking your question. Please read this: http://www.cfd-online.com/Forums/ans...tml#post421347 Frank |
May 27, 2013, 13:49 |
Harshad Lalit
Rep Power: 12 |
Thanks a lot EIvb for your reply.This will certainly help
Thanks Frank.Yes I did not look at the ICEM-CFD tutorials indepth but appreciate you sharing these links |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Loading previously saved mesh in ICEM CFD | user0314 | ANSYS Meshing & Geometry | 1 | September 20, 2011 12:46 |
[ICEM] Problem with volume mesh in ICEM CFD | kolapoasafa | ANSYS Meshing & Geometry | 2 | September 16, 2011 03:54 |
Boddy fitted Hexcore Mesh in ICEM Cfd | Mitch | CFX | 0 | December 29, 2008 06:07 |
How is ICEM CFD mesh file format? | Seth | CFX | 4 | March 2, 2008 17:22 |
