2D Airfoil- From ICEM to FLUENT
Hi guys, I'm new to the world of CFD and one of the project I've taken up doing is running a simulation of a 2D airfoil in Fluent to determine the Cl and Cd. I've followed the ICEM 3 part youtube video on creating the mesh for my airfoil step by step and I'm happy with the quality of my mesh. However, when I open the exported ICEM mesh in Fluent, it doesn't have any boundary conditions besides the far field. I doesn't have the inlet and outlet. This wasn't covered in the video, so I really don't know how to setup an inlet and outlet. Every Fluent tutorial I see already has those boundaries, while mine only has these:http://i.imgur.com/6CVTtbz.jpg
If anyone can help me get this simulation to work I'd really appreciate it! I've been struggling with this over the past two days and it's really become frustrating.:mad: Thanks! |
you must create corresonpding part (click on parts) and associate each edge to that particular boundary.
For example: In you have farfield BC for entire periphery. You should make two parts : 1. Inlet (or farfield) and 2. outlet (pressure outlet) . For this you need two step procedure: 1. Right click on parts > Create new part Name it In and select the inlet curve Repeat same procedure and create oulet part. 2. Associate edges to corresponding curves For your airfoil boundary (wall) : did you delete the inner block? Did you specify the boundary condition? What does crvs boundary represent in your case? |
Firstly, thank you for replying back to me so quickly! I'm still quite new at this so I have a few questions regarding what you said, and I'll try to answer your questions as best as I can:
Also, in regards to associating the edges to curves, which edge do I need to associate the inlet and outlet to? As you can see in the second image, my airfoil has a blunt trailing edge so I didn't collapse the blocks like in the tutorial video. Do I associate the curves to the vertical blue lines or the black lines? |
So I think I've understood how to generate the Input and output boundary conditions now I'm receiving a fatal error when importing the ICEM mesh into FLUENT. I'm pretty sure it's because my assocations are wrong, but I've followed the tutorial and all my lines are green.
I've attached a link to my project if anyone would like to look at it and help me figure out where I went wrong. http://www.filedropper.com/smoothed4 |
Where is the project ?
Sorry, I don't know why it deleted it. I'll upload again to Dropbox:
https://dl.dropboxusercontent.com/u/...OOTHED%204.prj |
it is only .prj. We need .tin and .blk (or at least .tin)
Sorry about that, I'm pretty new at all of this. I'll upload everything I have in that folder pertaining to that project file:
https://www.dropbox.com/sh/zh9fsepklvrrx2n/4x4wzwZdwl |
