[ICEM] How to generate unstructure mesh of this geometry?
Old   May 14, 2013, 04:35
Default How to generate unstructure mesh of this geometry?
Li
llrr is on a distinguished road
Hi Everyone, I would like to generate hybrid mesh using ICEM. The structure mesh will be genrated in the building, which has been cut off from the geometry in attachment. Then I would like to generate the unstructure mesh in this geometry in ICEM. I have never use ICEM to generate unstructure mesh. I tried many times but it still not succeed. Thank you for the help in advance.
Li
llrr is offline   Reply With Quote
Old   May 14, 2013, 20:34
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
would you mind having a look at the link in my signature, it's a small introductory guide in ICEM
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   May 21, 2013, 03:18
Li
Hi diamondx, I have read the documents. Because there is a very small gap, I always failed to generate the mesh there. Thank you.
Old   May 23, 2013, 01:12
Vimalraj
vimaero is on a distinguished road
Hi Li
I am using GridPro. It can create good quality mesh even in small regions. I can help you with this case if i get the geometry. Can you post the geometry in IGES or STL format?
vimaero is offline   Reply With Quote
Old   May 23, 2013, 10:00
diamondx's Avatar
Ghazlani M. Ali
the tin file does not work, can you share the hole project ?
Regards,
Ali
Old   May 28, 2013, 03:41
Li
Hi Diamondx,
Here is the project files.
Thank you.
Old   May 28, 2013, 03:42
Li
Originally Posted by vimaero View Post
Hi Li
Hi Vimaero, I do not have the access to GridPro software. Thank you for the help and information.
Li
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] Irregular mesh generation for simple box geometry ajl42 OpenFOAM Meshing & Mesh Conversion 0 March 7, 2011 17:04
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
