[DesignModeler] How to create the compressor fluid passage? |
May 28, 2013, 05:56 |
Maixiaoya
Rep Power: 13 |
Hello, everyone~~
I have the compressor rotor model created by Solidworks, and I want to make a simulation of the model, but I have no idea how to create a periodic fluid passage of the compressor ,like in the picture below. Can anyone be so kind as to tell me the tricks? |
May 28, 2013, 08:21 |
Ghazlani M. Ali
Rep Power: 28 |
you need to subtract a fluid domain. this is done by creating an enclosure around your blade, then applying a boolean operation so the blade are removed from the enclosure. this how you get the fluid domain. use the tool search in the forum to get more detail about how it is done. there are also videos on how to do that in youtube. if you can't find it, come back here i will show them to you, i'm a little bit in a hurry now
May 29, 2013, 22:51 |
#3 | |
Maixiaoya
Rep Power: 13 |
Thanks again~~ |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
