Home > Forums > ANSYS Meshing & Geometry
[ICEM] Multiple edges problem when merging hexa/tetra mesh
Old   May 30, 2013, 20:26
Default Multiple edges problem when merging hexa/tetra mesh
Andrew Kang
earth07 is on a distinguished road
Hi, I've been learning how to merge tetra/hexa mesh together
and now I know how to do it for an example in the tutorial.
I'm trying another simple but a bit different example trying to merge
tetra/hexa mesh.
As you can see from file below, I'm merging different sized boxes each with tetra and hexa meshes, and followed the procedure given in the tutorial.
Here's project file link right before merging the volumes.
http://www.2shared.com/file/JC9xFOfh/test.html
At frist, it seems to be working, but when I check the mesh,
I found 'multiple edges around the interface and I want to eliminate
all the multiple edges.
If any of you know how to tackle this problem, please let me know..
I'll really appreciate it..
earth07 is offline   Reply With Quote
Old   May 30, 2013, 22:20
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
an expert once said:
Multiple edges are simply edges with more than 2 surface elements connected. In this case, you have the side walls and the interface elements. This is listed under "possible problems" and not "errors". Your solver probably won't mind the multiple edges at all. However, if you want flow to pass thru the interface between the hexas and tetras you have two choices... Either set up the interface correctly in the solver to allow that to happen (this varies with the solver), or just delete the shells in the interface part before you export to the solver.
By Simon
Regards,
New to ICEM CFD, try this document --> http://goo.gl/G2gkE
Ali
diamondx is offline   Reply With Quote
Old   May 30, 2013, 22:56
Default I've read that already.
Andrew Kang
Thanks!
I've figured out the solution to my problem.
Old   May 31, 2013, 03:29
Javi
FJSJ is on a distinguished road
Hi guys,
If I want to do this "...or just delete the shells in the interface part before you export to the solver"... how can I do it? Is that I have not very clear.... Thank you guys!
FJSJ is offline   Reply With Quote
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 23 August 6, 2014 03:50
snappyHexMesh aborting Tobi OpenFOAM Native Meshers: snappyHexMesh and Others 0 November 10, 2010 04:23
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
