create mixing tank in gambit
Hi freiends
can you tell me step by step geometry making of stirred tank for use by MRF? I create impeller, tank, and moving zone(middle cylinder), but I dont know other steps. I use GAMBIT. Best Regards Reza |
-create your tank as solid
-create your impeller as solid -create the bouding box surrounding all your solid elements -substract tank and impeller from box Now you have the fluid domain Split your domain for being able to pick your moving zone (or setting it as moving fluid) Mesh |
Thanks for reply I dont understand. Bouding box surrounding all solid element? Tank is largest cylinder. please describe to me in detalis. Best Regards Reza |
I already described in detail.
If you build the tank and the impeller as solid, you are ready to compute stress analysis in your solids. But you want to compute flow analysis. So you need to mesh the flow domain. For that you need to extract fluid domain from solid. So you create a big domain (fluid), and you substract all you solid parts |
I know that for use MRF, we must be 2 domains, first is rotating domain and another is stationary domain. rotating domain is a bounding box around impeller(cylinder). Which one is your purpose to souronding box? I create three volume:tank, impeller and bounding box around impeller. I dont know how do subtract or split or others command,now. Thanks in advance Reza |
don't mix the steps.
Bounding box is only here for extracting your fluid domain. Once it is done, you do your split, and it divides your fluid domain into 2 subdomains: stationnary and moving. That's all |
please forgive me. Bounding box is large tank(main tank that we want to compute fluid flow in it), yes? |
No bounding box is a volume you will need to create the fluid domain.
I give you an example: you will compute flowfield around a cylinder (von Karman) You create the cylinder as solid. But you need the fluid domain around the cylinder. So you create an outer box (bounding box), and you will substract the cylinder from this box. As result you get the box BUT with the cylinder as hollow. |
thanks in advance your mean is a thing similar to wind tunnel. ok? but what is size and boundary condition of bounding box? diameter of tank is 0.3m radius of impeller is .045 Best Regards Reza |
Bounding box, will disappear once you created the fluid domain. So it won't have any BC
Post a picture |
hi reza
i am iranian if u want u can contact me by this address .i think that i can help u. behrooz_afra1990@yahoo.com |
Thank you so much, I do it. Best Regards |
