[GAMBIT] Fluid square cell in gambit
Old   June 4, 2013, 05:24
Red face Fluid square cell in gambit
Elena
kalene86 is on a distinguished road
Hi everybody!
I am an engineering student and I’m preparing my master’s degree thesis. I am studying Thermal Energy Storage Systems. In particular I’m focusing on air motion inside a cylinder of porous material.
In gambit to simulate pores I have to draw a fluid square cell (pore) “side 8mm” with a thickness of 1mm (for a total of 10mm) and 1000mm in length.
On the frontal external surface(thickness) I should put a 3x3 mesh, a 20x20 mesh in the pore and on the length I must make 300 knots. I wrote a previous post about a similar problem and you have been very helpful.
I hope you can do the same now!
kalene86 is offline   Reply With Quote
Old   June 4, 2013, 05:30
Default picture of a cell fluid
Elena
This is a picture of the cell fluid.
Old   June 4, 2013, 08:43
-mAx-'s Avatar
Maxime Perelli
what is the problem exactly?
Old   June 4, 2013, 12:03
Elena
how do I put 300 nodes on the length?
Old   June 5, 2013, 01:04
-mAx-'s Avatar
Maxime Perelli
mesh/edge
in spacing choose "interval count"
Old   June 5, 2013, 04:19
Elena
thank you!!!!
Old   June 7, 2013, 11:51
Default problem in fluent
Elena
Hi max!!
When I export the file in Fluent there is the following message:
Note: Separating wall zone 4 into zones 4 and 1.
wall -> wall (4) and wall:001 (1)
Note: Separating interior zone 8 into zones 8 and 7.
default-interior -> default-interior (8) and default-interior:007 (7)
What did I do wrong?
Old   June 9, 2013, 06:32
ghost82's Avatar
Rick
ghost82 will become famous soon enough
How many volumes do you have?
What is your domain?
Do you need internal parallelepiped?If not, did you subtract it from the external parallelepiped?
Post pictures.
Daniele
ghost82 is offline   Reply With Quote
Old   June 9, 2013, 13:59
Elena
daniele!
are you italian?i have a some difficulty to explain the problem in English! how can I contact you privately?
Elena
Old   June 10, 2013, 07:06
-mAx-'s Avatar
Maxime Perelli
it sounds like connectivity problem.
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
How to determine the direction of cell face vectors on processor patches sebastian_vogl OpenFOAM Programming & Development 1 October 11, 2016 13:17
How to choose the mean diameter value for dispersed fluid? creddy_trddc CFX 1 October 30, 2011 04:30
Warning 097- AB Siemens 6 November 15, 2004 04:41
Fluid Structure Interaction Apollo FLUENT 8 July 7, 2004 17:54
