Home > Forums > ANSYS Meshing & Geometry
[ICEM] Variable prism layer height
Old   June 5, 2013, 05:26
Default Variable prism layer height
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Hi guys,
I am simulating an ABL simulation in which there is a need for having a variable roughness value (z0) for the ground patch.
Long story short, I have managed to do this in OpenFoam, but I wonder if it is possible to have variable prism layer height in ICEM.
for instance in a desired zone on the patch "ground", I wanna have a first prism layer height of 0.1 and in the rest of the domain I want it to be 0.2.
I don't want to split ground patch into two separate patches like ground1 and ground2, which in this case there would be some problems in simulating it in OF.
Any help is appreciated,
Thank you
Mojtaba
Learn OpenFOAM in Persian for free, And ask your questions here.
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   June 5, 2013, 07:55
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
i don't know how you can do that if they have the same name. you need to give them different name. may be try giving them separate names like ground1 and ground2. generate your prism layer, then merge them together in one part again...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   June 5, 2013, 08:53
Mojtaba.a's Avatar
Dear Ali,
Thank you, but this method cannot merge two parts into one part completely. When I do that just geometries of two parts merge together and mesh parts still remain separated.
best
Old   June 5, 2013, 09:12
diamondx's Avatar
Ghazlani M. Ali
you can merge meshes too. in fact, mesh elements are also parts. you just need to select them. you want to merge all the prism layer into one part. if i recall well, prism are called Penta_6 in icem. toggle to unvisible all other type of element and leave only the penta_6 visible. then right button click, create part "ground". in my signature, i include a link to a guide where it shows how to select and create mesh part... i hope this will work for you
Regards,
Ali
Old   June 5, 2013, 14:12
Mojtaba.a's Avatar
Thank you Ali,
Let me see how it works and report it back.
best
Thread Tools
Trackbacks are On
Boundary layer in a pipe Clementhuon OpenFOAM Native Meshers: snappyHexMesh and Others 6 March 12, 2012 13:41
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
Why only one prism layer generated xiaoyoyo ANSYS Meshing & Geometry 0 August 26, 2010 20:17
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas Main CFD Forum 1 May 30, 2008 04:35
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
