Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] 3d structured mesh
Like Tree1Likes
  • 1 Post By -mAx-
Old   June 5, 2013, 09:04
Default 3d structured mesh
mohsen kh
m5m5kh is on a distinguished road
Hi friends
I post a thread about my problem in meshing with Gambit.
my model is a furnace with 72 eliptic holes around it.I want to remove some holes from the section of furnace which was shown in attached photos. I do not know how to mesh my volumes to have a structured map mesh.
I used to create surface and then substract it frome the surface of volume to call them inlet in my model but some one told me to create them as volumes. I want to have a map mesh or cooper but I do not know how to create it.
please help me if it is possible for you
thanks
http://i41.tinypic.com/33cx8ut.png
http://i41.tinypic.com/5bz2th.png
http://i42.tinypic.com/autgs1.png
m5m5kh is offline   Reply With Quote
Old   June 6, 2013, 01:23
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
if your elliptic surfaces are the inlet, then I would do a split in the z direction (negative): Use the lower circle adjacent to all your elliptic surfaces and sweep it in negative-z-direction.
Split your volume(s) with the generated surfaces.
Doing that you will isolate all your surface inlet on a volume, which will be meshable with cooper.
BUT for sur you will have a problem (skewness) because of tangential circles (upper and lower) --> possibilities are "merging" or adjusting both upper and lower circle radius for being able to insert one cell between circle and inlet surface
m5m5kh likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Thread Tools
Trackbacks are On
Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Native Meshers: snappyHexMesh and Others 8 September 13, 2012 09:28
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
Block structured hexagonal mesh vs automated tetra mesh inside Workbench for CFD Chander CFX 3 November 27, 2011 17:24
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
