June 10, 2013, 11:05 |
How to Import a DWG Geometry to ICEM?
Zi
Rep Power: 12 |
Dear all,
I suppose to Import a DWG format Geometry to ICEM due to i want do CFD modelling base on a existing AutoCAD model. I was tried to import it to ICEM. my steps are: Import Geometry----DWG-----slecet my dwg foemat file-----but it appeared Tetin file U:/Testing Model/Revit-Testing/CAD/Project1-3DView-{3D}.tin does not exist Any expert know why it is going wrong? And what is the right way to do it? Thank you very much for your time and valuable advice. Best wishes, Sky |
June 10, 2013, 11:24 |
Javi
Hi Zi,
Try with "Workbench Readers". File -> Workbench Readers -> Autocad (*.dwg,dxf) -> Select your file -> open.... Tell us if it works :-) |
June 10, 2013, 19:13 |
Rep Power: 19 |
It is asking for a tin file to save to.
did you not click the save button when it asked for the tin file? |
June 11, 2013, 05:20 |
It works!
Zi
Rep Power: 12 |
June 11, 2013, 05:29 |
#5 | |
Zi
Rep Power: 12 |
Hi mjgraf, Thank you for your advice. Yes, i did click save button. That is appeared after i click save button. Now i had solve. Thank you again Best wishes Zi |
June 11, 2013, 06:28 |
Javi
Hi zi,
I donīt know if itīs the proper way to import CAD models or not... but I always work with CATIA and I always use this option instead of import geometry. I can chose if I want to import lines, points, surfaces from my model or simply the solid parts. |
June 11, 2013, 06:43 |
#7 | |
Zi
Rep Power: 12 |
Thank you so much for your advice. I got it! Best wishes Zi |
cad model, import geometry |
Import Mesh from ICEM CFD to CFX | Andre Almeida | CFX | 16 | April 19, 2016 03:42 |
geometry import problems (STEP into ICEM) | Toralf | CFX | 10 | March 7, 2014 21:17 |
[ICEM] Export Geometry from the ICEM | asal | ANSYS Meshing & Geometry | 4 | February 3, 2013 08:01 |
flow over an airfoil 3d ( Geometry on icem cfd ) | dfmona | Main CFD Forum | 0 | April 13, 2010 23:32 |
ICEM: Holes in Geometry | Daniel | CFX | 4 | February 22, 2009 09:40 |
