[ICEM] Got a question about 'copy periodic blocking' and 'o-grid' |
July 2, 2013, 08:52 |
Andrew Kang
Rep Power: 12 |
Hi, I'm just constructing the full passage grid for turbine nozzle part.
When I copied a single passage without O-grid using 'copy periodic blocking' function, it worked well. After putting an O-grid around stators, however, if I use 'copy periodic blocking' function, it takes forever. My computer is one of the best model nowadays and it's been taking a couple of days and it's not been done yet. Is there any possible reason for this problem? I tried 'block transform', but this seems not very helpful since all the associations seem to be done again. Any suggestion or help will be appreciated. Thank you for reading.. |
[ICEM] o grid blocking strategy? | icemaniac178 | ANSYS Meshing & Geometry | 14 | March 19, 2013 23:18 |
[ICEM] Structured grid without blocking in ICEM | BahaZero | ANSYS Meshing & Geometry | 19 | March 5, 2013 11:36 |
[ICEM] Copy Blocking and Geomtry with Associations | Mick | ANSYS Meshing & Geometry | 2 | September 30, 2011 09:53 |
[ICEM] Blocking advice for periodic cascade. | jordan | ANSYS Meshing & Geometry | 0 | October 20, 2010 22:40 |
Blocking of Grid to a certain height is possible? | jogendra | FLUENT | 2 | October 19, 2005 03:20 |
