-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] ICEM Wing (http://www.cfd-online.com/Forums/ansys-meshing/119766-icem-wing.html)
syavash June 24, 2013 14:42
ICEM Wing
2 Attachment(s)
Dear mates,
I want to generate hexa mesh around a 3-D simple wing by ICEM. I have constructed the blocks correctly (I think!) but grid is not generated. I need your help to figure out what the problem is. Simon & Far, I think you can resolve the problem. I have attached my project files and an image.
Thanks
Far June 25, 2013 08:37
There are few problems which should be rectified:
1. No of nodes are very few.
2. Delete block(s) inside wing or change its material
3. Create o-grid inside the wing tip which extends into far field.
syavash June 25, 2013 08:52
Originally Posted by Far (Post 435841)
Dear Far,
thanks for replying,
I could get your point concerning deleting block inside the wing. But two other points are not clear to me.
I have already constructed an O-grid from tip toward the far-field (as your tutorial in youtube).
Please tell me why I should increase No. of points on the wing? (and how?)
Far June 25, 2013 08:56
download video. Upload will take some time (may be 2-3 hrs). mean while you will get message error 403 or 404
https://dl.dropboxusercontent.com/u/68746918/wing.mp4
syavash June 25, 2013 09:04
As you mentioned I am getting error 404 while downloading it. but let me ask what this video is about?!
syavash June 25, 2013 09:11
Originally Posted by syavash (Post 435855)
Dear Far,
I think you intended to say that there are not enough MESH points on the edges, am I right?!
syavash June 25, 2013 09:19
I think the problem is with the inner face of O-block inside the wing tip. mesh is not generated for that region at the wing root and outer far-field block face.
But the wing tip is totally mesh-less (even the O-grid around the inner face). Why is that so?! Have any Idea??
Far June 25, 2013 11:42
yes, it shows file is still not uploaded
syavash June 29, 2013 13:04
Dear Far,
thanks to your comments I could generate the grid properly, now my problem is with boundary conditions. I know how to define BC in 2-D. But in a 3D case I have no experiences. I have tried to build 6 parts by 6 corresponding surfaces of the domain (a cube). Then I have associated the block faces to these 6 surfaces. I think this is a right method but is very time consuming.
Is there any better and shorter way to define BC in a 3D geometry?!
Thanks
Far June 29, 2013 13:41
Do not associate faces to surfaces. It is done by icem by default.
syavash June 29, 2013 14:01
So how does Fluent recognize the BC faces?! Shouldn't we associate any elements? what about edges or vertices?!
Far June 29, 2013 14:06
It will. However you have to associate edges and vertices to curves and points respectively.
