June 24, 2013, 14:42 |
ICEM Wing
Syavash Asgari
Rep Power: 18 |
Dear mates,
I want to generate hexa mesh around a 3-D simple wing by ICEM. I have constructed the blocks correctly (I think!) but grid is not generated. I need your help to figure out what the problem is. Simon & Far, I think you can resolve the problem. I have attached my project files and an image. Thanks |
June 25, 2013, 08:37 |
There are few problems which should be rectified: 1. No of nodes are very few. 2. Delete block(s) inside wing or change its material 3. Create o-grid inside the wing tip which extends into far field. |
June 25, 2013, 08:52 |
#3 | |
Syavash Asgari
Rep Power: 18 |
thanks for replying, I could get your point concerning deleting block inside the wing. But two other points are not clear to me. I have already constructed an O-grid from tip toward the far-field (as your tutorial in youtube). Please tell me why I should increase No. of points on the wing? (and how?) |
June 25, 2013, 08:56 |
download video. Upload will take some time (may be 2-3 hrs). mean while you will get message error 403 or 404
https://dl.dropboxusercontent.com/u/68746918/wing.mp4 |
June 25, 2013, 09:04 |
#5 | |
Syavash Asgari
Rep Power: 18 |
June 25, 2013, 09:11 |
Syavash Asgari
Rep Power: 18 |
June 25, 2013, 09:19 |
Syavash Asgari
Rep Power: 18 |
I think the problem is with the inner face of O-block inside the wing tip. mesh is not generated for that region at the wing root and outer far-field block face.
But the wing tip is totally mesh-less (even the O-grid around the inner face). Why is that so?! Have any Idea?? |
June 29, 2013, 13:04 |
Syavash Asgari
Rep Power: 18 |
Dear Far,
thanks to your comments I could generate the grid properly, now my problem is with boundary conditions. I know how to define BC in 2-D. But in a 3D case I have no experiences. I have tried to build 6 parts by 6 corresponding surfaces of the domain (a cube). Then I have associated the block faces to these 6 surfaces. I think this is a right method but is very time consuming. Is there any better and shorter way to define BC in a 3D geometry?! Thanks |
June 29, 2013, 14:01 |
#11 |
Syavash Asgari
Rep Power: 18 |
[ICEM] Meshing sinusoidal leading edge wing in ICEM | ryerson_guy | ANSYS Meshing & Geometry | 39 | April 10, 2013 02:57 |
[ICEM] ICEM mesh problems for sinusoidal leading edge wing | ShowponyStuart | ANSYS Meshing & Geometry | 20 | March 21, 2013 19:00 |
[ICEM] 3d mesh around a wing using ICEM | artemis64s | ANSYS Meshing & Geometry | 6 | September 23, 2011 07:59 |
ICEM meshes inside my wing | LBRS | Main CFD Forum | 6 | February 21, 2008 09:09 |
ICEM - mesh near wing trailing edge | Joao Lourenco | CFX | 5 | August 30, 2007 17:20 |
